Hello All,
I have a 40' LOA aluminum power cat that I use for cruising/fishing/toy hauling here in Southeast Alaska. It's powered by Volvo D-6 370's with DPH outdrives. Yes, it's a bit of a fuel hog, but I've learned this amazing thing...if I slow down, I don't burn so much fuel! The addition of an autopilot this year made a huge difference in tolerating displacement speed running.
Last week I experienced my second major Volvo outdrive failure. The first failure was addressed under warranty, but this one is three months past the warranty period. Reason for failure is as yet unknown until the boat is hauled and the outdrive removed. A new replacement drive is...$11,000!
I'm reaching the conclusion that the Volvo outdrives can't handle the power/torque of their diesel engines. I'm reluctant to install another $11K unit if it'll fail after 400 hours. Instead, I'm thinking about converting my cat to a canoe stern displacement hull, similar to the Malcolm Tennant design. I think it may be feasible, though I understand that I won't see quite the same efficiency that a purpose-built displacement hull would provide. Still, it would be more efficient than running at displacement speeds with outdrives on a flat transom. And I would avoid the reliability and maintenance headaches that the outdrives are giving me.
I'd consider buying a new boat but my budget won't allow, and I have this one customized exactly to my liking - I love the boat other than the outdrives and fuel economy.
Thoughts? Experiences? AM I nuts? Am looking for technical references to the canoe stern design concept. Any links you can send my way?
Thanks in advance...
