Old 05-03-2008, 02:27 PM
Bullshipper Bullshipper is offline
Bullshipper
Rep: 21 Posts: 40
Cat sponsons- displacement forward,planning?
1st post here.
Meant to say displacement forward, planning aft.
Looking for your thoughts on a new to me concept for designing power cat sponsons for 50 kph crusing speeds.
The idea is to go with a sponson bottom that is
knife like forward, protuding forward of the deck area to lessen tunnel slap and be efficient at low trolling speeds.
Transition to semi displacement midships with slightly deeper sponson camel height to provide more lift to bow and stern
Transition into 13 degree planning surfaces aft so that when more power is applied and the bows tilt up, the aft planning surfaces lift the to get better speed on smaller wetted surface area.
Stern heavy flat attitude when trolling, with more bow lift at speed.
Old 05-04-2008, 08:04 PM
CTMD's Avatar
CTMD CTMD is offline
Naval Architect
Rep: 117 Posts: 196
How big is the boat? The is a big difference in required hull form for a 7m and 17m cat at 27 knots.
Chris Tucker Marine Design
Your Boat Your Way.
www.ctmd.com.au
Old 05-04-2008, 09:02 PM
Bullshipper
Rep: 21 Posts: 40
Hi Chris,
I believe you helped Roger Hill and I with the design on a 7 m trailer hull for Mexico a while back.
This is for a 29'x11'11" project.
Old 05-04-2008, 09:43 PM
CTMD's Avatar
Naval Architect
Rep: 117 Posts: 196
Yes, that's me, I worked with Roger for a number of years and we still work together on occasion. How did the boat turn out? If there is anything I can help you with please don't hesitate to ask, either here or via email (chris (at) ctmd.com.au) .
At 30' you'll definitely be looking for some lift at 27 knots. It sounds counter intuitive, but your efficiency at low speed on a power cat has more to do with the stern than the forefoot (bow). Obviously a pointy front will help but a planning stern will be like dragging a bucket when you are going slow. I'm assuming this will be an Aluminium boat so you'll also need to make sure all the plates are developable or it could get very expensive to build.
Your Boat Your Way.
www.ctmd.com.au
Forward Looking Sonar Pericles OnBoard Electronics & Controls 3 12-17-2007 10:24 PM
Planning hull drag at displacement speed? steveislucky Boat Design 12 12-17-2007 05:12 PM
tri-hull or v with sponsons? flyguy Powerboats 3 06-07-2006 12:18 PM
Forward props Akeswins Props 8 06-10-2005 09:48 PM
SPONSONS=Porpoising??? input please!!!! seaARK03 Boat Design 6 11-10-2004 02:12 PM
