Old 05-19-2006, 06:39 PM
kachok25 kachok25 is offline
Rep: 10 Posts: 5
cat plans
I am looking for some plans to build about a 19-20' long 8-8.5' wide catamaran. I don't know if anybody makes any plans for such a widebody design, so any pointers on designing my own would be helpfull. I am primaraily worried about the boat splitting down the middle, and what reinforcements would be needed. I am trying to make a go anywhere fishing boat.
Old 05-20-2006, 12:43 AM
Figgy's Avatar
Figgy Figgy is offline
Rep: 88 Posts: 315
Something like these?
http://www.nzboatbuilders.com/sportfishingcats.asp
Imagination is more important than knowledge.
-Einstein
Old 05-20-2006, 03:10 AM
Guest-3-21-09-10-33
fisherman 20 ft catamaran
see:
C-C 20 Power Fisherman Catamaran
on
http://www.ccplans.com/index.cfm?Fus...&wysiwyg_id=53
Dimensions LOA (Incl. B/P.4m) 6.1m 20' 10' LWL 5.3m 17' 11'
Beam 2.5m 8' 2'
Draft (hulls only) 0.425m 1' 5'
Displacement About 3.5 tons (ready to rev.)
Motors From 2x20 HP up Depending on Preformance Required
Old 05-20-2006, 11:11 AM
Rep: 10 Posts: 5
Cool stuff but not what I was looking for. I am talking about a lightweight, (under 800kg, 1,760lbs) Center console, shallow draft, single outboard engine. My goal is to make a boat that can fish the shallow flats and marshes, as well as in 7ft seas. I am opting for the cat design because they have a well know reputation for handeling rough seas as well as a V-hull twice their size, not to mention the improved stability at rest. I do have one more question though, what is the major difference between the twin hull and the tri-hull?
Old 05-20-2006, 11:24 AM
Figgy's Avatar
Rep: 88 Posts: 315
In all honesty your asking for a preaty tall order. There is no question one can be designed to your specs, if one isnt already out there, but expect it to cost a preaty penny. I'll keep my eye open, but searously consider contacting a NA for a project like this.
-Einstein
Old 05-20-2006, 11:38 AM
Rep: 10 Posts: 5
I know it is a tall order, but I am not trying to build a boring boat. Twinvee builds a 19 foot cat that weighs in at 1200lbs. My problem with that boat is that the beam in too narrow, and the small 36gal fuel tank.
Old 05-20-2006, 11:41 AM
Rep: 10 Posts: 5
Another problem with those custom builders you recomended is that I live in the US, and they are based overseas. I am probably going to have to build the boat myself.
Old 05-21-2006, 10:11 AM
Figgy's Avatar
Rep: 88 Posts: 315
That boat is only six inches narrower than what you want, but ok, I understand. About the fuel, you could work that one out. Bigger or another tank.
If your talking about my post, that site sells plans.
Now don't take this the wrong way, but if your going to be super picky about a boat(we all are when is involves this much cash), you should just have it drawn up by a pro. There is no point in looking for a boat that is going to be "good enough". Your going to drop alot of cash, and spend alot of time building a boat, make it the one you want. "Good enough, isnt".
-Einstein
Old 05-24-2006, 02:43 AM
Guest-3-21-09-10-33
could be of interest?:
5.5m powercat
Power Cat Plans drink8 Fiberglass and Composite Boat Building 3 09-14-2005 10:07 AM
Steel Cat Fitcher Metal Boat Building 2 10-06-2004 01:36 PM
Offshore CAT help Catman Boat Design 0 06-26-2003 12:37 AM
power cat plans snapper340 Boatbuilding 1 01-28-2003 12:38 AM
Cat or Mono or............................ Nomad Option One 12 05-31-2002 08:48 PM
