cat hull transom height
G'day Guys,
I am currently working on an amateur design for a 4.2m(14ft) cat runabout to be powered by a single Honda 4 stroke 50Hp. Similar idea to the ducks(mono hulls) used by the surf life savers and thundercats in Australia. I am chasing help with information on transom heights for a single engine installation. Mono hull and twin engine cat are straight forward with plenty of information from both manufacturers and designers available, however I cannot find anything relating to single engine installation. Are the principles of transom height the same for all designs or am I opening up a can of worms. I realise as with most boat setups there is final trimming here and there depending on real world/water performance, I'm just trying to remove the guess work on a major aspect of the design and resulting performance.
Cheers
