Old 11-24-2002, 06:52 PM
b_rodwell b_rodwell is offline
Rep: 11 Posts: 60
carbon propellers?
I am interested in designing a battery/diesel electric drive for a 70' sailing catamaran. Not disimilar from the Solomon approach. I have worked out most of the components but I am not happy with the propeller. Following the advice in the books I went for a low rpm solution (1000rpm) and came up with a 24" diameter x 15" pitch. I have plenty of space but I don't like the weight estimated at 40lbs.
I seems to me that propellers could be made from carbon. They should be lighter and less expensive. I have searched on Google but could only find outboard propellers and air propellers. Has anyone heard of suppliers for non-metalic propellers in this size range?
Old 11-25-2002, 06:50 AM
yipster's Avatar
yipster yipster is offline
Rep: 1083 Posts: 3,337
yes they do exist, i've seen them.
they came with a lot of long bended blades and in sizes as you mention. less expensive i doubt but do recall a dutch comp. on a show here some years back with that. maybe it was experimental and probably there are more. i'll see what i can find.
Old 11-27-2002, 02:46 AM
Rep: 11 Posts: 60
I think the hunt for my carbon propeller is getting warm. Holland sounds good. If you look at page 90 of the September issue of Yachting World there is a photo of a carbon propeller that is getting closer.
I did a google search on the boat builder mentioned in the article - Johan Vels Jachtbouw. I got 5 hits but they were all in Dutch - not very helpful to me. Are there any surfers out there who can read Dutch? I am looking for the company that built the propeller. A web URL would be great but, failing that, a name and phone number.
Thanks
Old 11-28-2002, 03:53 AM
lockhughes's Avatar
lockhughes lockhughes is offline
ElectricGuy
Rep: 27 Posts: 110
Location: Wards Island Toronto north shore, Lake Ontario
How's your Swedish? ... just kidding, their site has English pages:
http://www.propulse.se/english/index.html
Sorry, not sure of size ranges. Custom negotiable maybe? (They're going to have to get up to speed with the electric crowd sometime eh? <wink>)
Cheers
Lock
Old 11-28-2002, 07:45 AM
yipster's Avatar
johan vels adress and phone:
Jachtbouw johan vels
tel. 0227 545062
adress: zeldenrust 11 medenblik Holland
his phone dont answer at the moment and his site i cant find that easy.
i have not seen the September issue of Yachting World yet.
the props i was refering to i cant find the folders back on nor an adres, that were big props, iff i recal well made to order, and i started a little inquiry to find them.
yipster
Old 11-28-2002, 11:50 AM
yipster's Avatar
ps: forgot to mention i'm dutch and can read (a little) if you want some translations gimmy the url's and articles.
the props i have seen some 6 years back on a show were yellow/green not carbon. but just what your looking for i thought.
posted a info. or.... on a sailing cat you do want that big prop pichable or as saildrive i asume?
and yip, it should be easy'er to find these things!
Old 11-28-2002, 11:15 PM
Rep: 11 Posts: 60
I plan to use the propeller with an electric motor, all mounted in an structure similar to a conventional outboard. When sailing the unit would be tilted and the propeller would be completely out of the water.
Accordingly I have no need to alter the pitch to reduce drag. A 'nice to have' would be the facility to change the pitch as part of the tuning for optimal performance.
Old 12-01-2002, 02:34 PM
Mike D Mike D is offline
Rep: 458 Posts: 102
The site given by lockhughes misbehaves(?)
I've been there a few times. The first time it only showed the home page with nothing else.
The second time the same thing but I clicked repeatedly on the word home just under the pic of the propeller. It took an age but finally a menu appeared showing range of sizes and power, adjustments to pitch and so on.
There is even a US distributor but what a surprise when I visited his site.
Michael
Old 12-01-2002, 03:33 PM
Rep: 458 Posts: 102
b_r
Here’s the result of a very fast search
http://www.acepropeller.com/pages/composite.html
http://www.henleyspropellers.com/propeller_range.htm
I suppose you’ve seen them it’s just that the second one mentions sizes up to 83” dia which is hardly an outboard (Jolly Green Giant’s excepted )
They were what seemed the most relevant but there might be some others, try this
http://www.google.ca/search?q=propel...start=100&sa=N
mostly not applicable but some interesting reading nevertheless.
I would appreciate if you could post a little info about your design and keep us “up to date” on your progress. Electric propulsion is the way to go if you can afford the extra costs involved but that torque “curve” is something else again.
Good luck
Michael
Old 12-05-2002, 10:51 AM
yipster's Avatar
thanks for the search, i coulndnt find it back but this looks very similar. mayby the "combination of carbon, aramide and highly drawn polyethylene" made me see that "Jolly Green Giant "
yipster
Old 12-05-2002, 06:47 PM
The propellor in the picture is a Contur F and is manufactured by
AIR Fertilug-Technologie Gmbh
Phone 49(0) 38295 77 78-0
air.rostock@t-online.de
Old 06-20-2003, 11:13 AM
yipster's Avatar
World's largest composite propeller successfully completes sea trials
more info on this Jolly Green Giant 2.90 metres diam. prop at http://www.qinetiq.com/news_room/new...r/world_s.html note data logging system
Old 04-14-2004, 04:30 PM
Craigg Woodman
School Teacher
Try an organization called "Free Enterprises" They make several carbon fiber props of various ranges...very efficient. They actually specialize in man-powered hydrofoils, but make some very big props too.
Old 11-01-2004, 08:17 AM
Cordelia
For info, QinetiQ have designed, manufactured and installed a large (~3m) composite propeller which has been very successful in sea trials. If you are interested in a specific design then please contact the team via the website on http://www.qinetiq.com/home/contact/QQenquiryform.html or by phone on +44 (0)8700 100 942.
Old 09-09-2006, 04:22 PM
waqas20 waqas20 is offline
Rep: 10 Posts: 3
Q-SPD have a carbon fibre system google Q-psd for more info
e-glass vs. aramid/kevlar vs. carbon JEM Materials 12 06-12-2005 03:19 PM
What is Carbon Carbon? Hypercat Fiberglass and Composite Boat Building 2 05-06-2005 09:13 PM
Carbon mast construction in 2 female 1/2's bjl_sailor Fiberglass and Composite Boat Building 4 05-01-2005 11:30 AM
Corrosion between Al and carbon grob Materials 11 02-18-2005 11:39 AM
carbon monoxide boating deaths Guest Open Discussion: All Things Boats & Boating 7 10-28-2003 08:51 PM
