  #31
Old 06-22-2010, 05:52 PM
freeboatrsrce freeboatrsrce is offline
Rep: 10 Posts: 20
Hello All,
As I'm sure most everyone knows, 100 pounds is about as far as you would normally want to go for car topping a boat. That's for a person who can handle 100 pounds. 150 pounds is alot of weight for a small person. Hauling a trailer around Chicago does not sound like any fun either. Of all the suggestions given, the video showing the side loading looks like the most affordable way to go, though maybe not the safest. This is like a real "invention" going on here! If you find it to heavy to push the boat up the ramps, make the ramps longer to reduce the vertical weight component. If friction is a problem, rig up some type of roller system where the boat makes contact with the ramps. If the boat can be rolled up the ramps, it should be easier to car-top the boat. Make sure the ramps are deep and wide enough so they will not break under the load. A 150 pound boat would have 37.5 pounds on each contact point. You would also want some type of "stop system" so the boat can't fall off the oppposite side of the car (and possibly land on someone). All of this would need to be thoroughly tested before being put to use, or someone could get hurt. Regardless of the system used, a person who is trying to maneuver more weight than they can safely handle is at risk of being injured. Pre-engineered systems are the best way to go as they have been tested for safety.
Wayne
www.freeboatresources.com
  #32
Old 06-22-2010, 07:35 PM
science abuse science abuse is offline
Rep: -3 Posts: 82
When I trailer an object that's too small to see, I affix one or two marking posts (from hardware store, lawn and garden, wood or fiberglass) to the unseen extremities of the trailer, such that they stick out/up into view.
  #33
Old 06-23-2010, 08:59 AM
Rep: 10 Posts: 20
I can't see my trailer!
Another option is to attach extension mirrors to your car or truck. I used to add 18 inch extenders to my tractor so I could see around the "Over-Sized Load" I was pulling on a flatbed (tractor-trailer). Extension mirrors allow you to see all of the trailer you are pulling AND the vehicle behind you.
Wayne
  #34
Old 06-23-2010, 10:02 AM
kach22i's Avatar
kach22i kach22i is offline
Architect
Rep: 1067 Posts: 2,299
Originally Posted by Jeremy Harris View Post
Rhino Rack........... 80 kg = 176 lbs...........nearest dealer to Ken is near Rockford:
http://www.rhinorack.com/GMapDealer.aspx
Dealer Name Family Tent Camping
Address
3708 Lakeview Dr
Winnebago IL 61088
Telephone (866) 917 4083
Fax
Email
Region Winnebago
Trading Hours
George: Architect (land lover type)
Hovercraft & Vintage Porsche Owner
http://www.boatdesign.net/forums/boa...ect-11973.html
  #35
Old 06-23-2010, 01:12 PM
kroberts's Avatar
kroberts kroberts is offline
Rep: 178 Posts: 282
Info is appreciated, but the purpose of the thread no longer applies. She will manage transportation without my input, and quite probably without my presence.
Thanks anyway.
-- Ken
No builds yet. Learning first!
  #36
Old 06-23-2010, 01:55 PM
troy2000's Avatar
troy2000 troy2000 is offline
Rep: 1686 Posts: 1,240
Thanks anyway.
That's probably the best solution, all the way around.
"All one has to do is follow the plans and build in no permanent leaks."
-Charles Minor Blackford, on the simplicity of building flat bottomed boats
car topper rowboat advice fish_head_soup Boat Design 15 09-19-2010 06:17 PM
Car Motor For Inboard kobus Inboards 17 05-17-2010 04:24 PM
woman convicted for plot to kill couple for yacht longliner45 Open Discussion: All Things Boats & Boating 16 10-08-2007 01:39 PM
First woman to win the Transat 6,50? Guillermo Sailboats 0 09-25-2007 12:45 AM
Tours Topper? ernie Boat Design 0 09-03-2006 06:48 PM
