#76
| Nice emergency kit. However, let's not hijack the thread I think the design is bad, for the Horn or elsewhere.
__________________ Gonzo |
#77
| http://www.periple.com/ is what I call a Cape Horn sailing yacht, capable of being single handed, extremely solid, versatile and most of details practical. Might not be a purist's dream, but I thought it was perfectly set up for the region around Cape Horn and Antartica. |
#78
#79
If you don't know that please, learn. Did you heard about BALANCING a boat with a two mast rig, or with a cutter rig (cutter rig as one mast in case you don't know that.) By the way, try sailing a real sail boat, you will enjoy. Don't give me the "take your medication" it is stupidly insulting from someone who has no clue about what is talking about. Please refrain to show your ignorance. It will reflect negatively on your book sale Daniel |
#80
#81
#82
| Angel, The answer is in post #68! |
#83
| Quote: Sorry folks for the rhetorical question about a point that already was made. Before responding I should have read the whole thread instead of a quick scan for designs. Good Luck! Angel |
#84
While I have had my 31 sailing and balanced perfectly on a broad reach in 15 knots of wind, balancing doesn't work well with all boats, especially downwind, which ,with a little planning, will be most of your voyages. It would be foolish, and just plain bad seamanship, to not take advantage of the advances in self steering, and the sheer simplicity of it. Balancing a boat every time there is a wind shift , or chance in wind strength ,is anything but simple. Been there done that. If it were as simple as some simpletons suggest, there woulk be far fewer windvanes on cruising boats. I thoroughly enjoy sailing my curent boat , far more than my tank tested first boat , designed by someone many consider a "Guru." I apologise for insulting someone who has no idea what he is talking about, namely you. It was you who started with the insults. My response was appropriate. I wouldnt sell my right to respond for the price of a book. My thinking outside of "Consumer Groupthink " is what makes my book so valuable. |
#85
#86
And then you start the: Quote:
You don't know what you did. But I don't care. What I care is boat problems solving. You have opinion which you transform on rule. This is very wrong. As a naval architect (if you are one) you should know better then this attitude is a certainty for making huge errors. I read your answer on the plating and framing, a student naval architect or boat builder will not have made this mistake after one month of learning. You are perhaps a good librairien, and take care of books, but what you put inside your books about boat must be questionable at best, after reading your posts. Questioning yourself is the first step you should do when you debate on a subject. I do it all the time, and guess what? I learn. After more than forty years I still learning, even with all the degree and experience which will make you a little kiddy. But this is very irrelevent if you don't continue learning all the time, day after day, customer after custmer (yes you can learn a lot from customer) other professional, other people, all around. Learning is also from the forum. Do not write books, open your mind, take the time to learn, as I do, don't be arroguant, it doesn't worth it. It is just boat. Cool off. And learn. Daniel |
#87
| In the last 40 years I have build over three dozen steel boats, and I have learned from every one. They have endured many torture tests, and have come out intact, and all the owners who followed the plans, were extremely happy with them. Each is a slight improvement on the previous. Otherwise I wouldn't have been able to take the building process from primitive , imitation wooden boat building methods, to hulls that are far fairer, more seaworthy and which take one tenth the man hours of the traditional methods. Boy , the trouble, expense and time I would have saved if I had the contents of my book back then! I make no apology for trying to pass on what I have learned to save others the trouble it would have saved me. What is the biggest problem facing those who want to get out and enjoy the cruising life? The one problem that gets the least amount of effort and innovation, on this and other sites. How to reduce the tremendous amount of work , time and expense of getting good seaworthy boat together. The "Be reasonable and do it the hard way" type of thinking seems to be the prevailing train of thought on may boat building sites. When someone tries to mislead others into believing the hard, expensive , super time consuming way is the only way , threatening to make having a good steel cruising boat the exclusive domain of the rich, do I get pissed off ? When someone tries to pass of outdated dogma and outright ******** as the only way to think, do I get pissed off? Damned right I do. No advancement in technology was ever accomplished by those who refused to question traditional ways of doing things, but who simply read the books, and do exactly what every one else does, and protested loudly when anyone ever suggested there may be a better way. Now that is what I call refusing to learn! I will always challenge ******** whenever I encounter it. That is how progress is made. |
#88
| The sites are also full of people reinventing the wheel. They claim that an hexagon is better than the traditional round ones and that any sensible argument is people that are too obtuse to be able to change. New or different is not necessarily better. Tried and proven has a lot to recommend. Hard to build and expensive are not traditional ways. Boats were traditionally built as quick and cheaply as the current technology allowed.
#89
__________________ Rick Beddoe s/v Soñadora, 1978 Baba 30 Senior Designer, Sons Creative "Study nature, love nature, stay close to nature. It will never fail you" - Frank Lloyd Wright |
#90
| quote, Brent, to hulls that are far fairer, more seaworthy can you explain this ? |
| Teenage sailor Abby Sunderland approaching treacherous Cape Horn | Boston | Open Discussion: All Things Boats & Boating | 1 | 03-29-2010 09:46 PM |
| Hire a Captain at Cape Coral FL | josera64 | Services & Employment | 0 | 06-18-2009 02:41 PM |
| Cape Horn Boats Concern | jiggerpro | Boat Design | 8 | 03-25-2008 06:48 PM |
| Green horn needs lots of help | Roger Brooks | Fiberglass and Composite Boat Building | 0 | 01-17-2006 06:52 PM |
| East Cape | lynnburcher | Metal Boat Building | 5 | 11-10-2004 08:53 AM |
