Old 10-01-2005, 06:34 PM
Thaddeus Thaddeus is offline
Eccentric
Rep: 10 Posts: 24
Location: 44.93N -93.13W.. not far from the Sweetwater Sea
canting keels: how are they displaced from side to side?
Hello,
I know canting keels are a relatively new innovation. I am curious as to how the keel is made to move to and fro as needed. Big hydraulic rams? Pnematics?
Any links to examples would be much appreciated.
thanks
Thaddeus
Old 10-02-2005, 06:28 AM
Karsten Karsten is offline
Rep: 22 Posts: 146
They use one or two big, chunky hydraulic rams. To power the rams they have to run the engine which drives the hydraulic pump. The modern ones run the engine non stop and also have all the winches powered hydraulically. The propellor is also driven by a hydraulic motor so if the engine fails you end up with a very expansive rowing boat.
Old 10-02-2005, 08:22 AM
Tim B Tim B is offline
Rep: 763 Posts: 1,384
Some are moved by a block and tackle system, but that tends to be for smaller boats.
Tim B.
Old 10-02-2005, 10:46 AM
User_U User_U is offline
Rep: 61 Posts: 50
like we tried with a Melges 24 - more pictures you will find here:sailormade - homepage
it was an interesting project
Old 10-02-2005, 11:48 AM
Doug Lord
Canting Keels
You'll probably learn more if you do a search in the "Sailboats" forum of this website under canting keels. There are at least two threads of interest: "Canting Keels" and a "CBTF"(Canting Ballast Twin Foil").
Old 10-02-2005, 05:22 PM
Eccentric
Rep: 10 Posts: 24
User_U, that's fascinating. How heavy was the bulb?
Twin keel research MikeJohns Boat Design 125 06-16-2009 11:44 PM
Canting Keels In Production Yachts D'ARTOIS Sailboats 169 02-17-2006 06:06 PM
technical papers or publications on canting keels danwupperman Boat Design 1 03-15-2005 07:28 PM
canting keels... seamonkey Sailboats 39 01-06-2005 08:54 AM
Swing keels? Kevin H. Sailboats 11 09-12-2004 06:08 PM
