| Canoe vs Kayak bow? Greetings everyone! New member here. I hope someone can tell me the functional difference between the curved up shape of a canoe bow vs. the sharper, angled bow of a kayak. I'm about to start construction of a solo open canoe/kayak using kevlar/fiberglass composite layup on a male mold as in James Morans book and I'm trying to finalize the design in my head before going further. Thanks! |
| Good canoes and kayaks have the shape determined by use and the materials available to build them. In general canoes are flat water boats and kayaks are used in white water and the sea. There is a million designs and the one thing they all have in common is that they fill an intended need. What is your need? Gary
__________________ "The hand feeds the mind." Weston Farmer |
This distinction is not universal though. Some canoes such as OC1s have an enclosed deck and a self-bailing foot well so they will plough through waves without taking in water. A more common distinction is that a canoe paddler uses a single bladed paddle while a kayak paddler has two blades. If you posted pictures of the difference you have actually observed there might be a more specific answer. Rick W |
| There are boats that are halfway between canoes and kayaks and therefore there is no single factor seperating the two types, only a recognition based on more factors being present to define the type. As mentioned, decking, double paddle, rough water usage, and sharpness of bow, but also flow reeboard to sheerline, ability to roll, narrow beam, seating down low, and use of spray skirt also define a pure kayak. Few kayaks, however, have every one of those features, and many canoes share some of those features. Many decked canoes are marketed as kayaks by the above definitions. With language, we come to expect a sort of mathematical precision when it comes to words, but you can see that there is no last word when it comes to definitions, since their usage is in living language and the usage defines the meaning, and usage changes all the time. For instance, you yourself can change the meaning of "kayak" simply by calling your own canoe a kayak. Only a miniscule change, but it has an effect that ever so slightly changes the meaning forever. |
| x3, there really isn't a clear line. My personal view is that a kayak is designed to handle water coming over the top, either with a deck and optional skirt or a self-bailing cockpit like the sit-on-top kayaks. A canoe is designed to keep water from coming over the top in the first place, but if it does it'll fill up. That's my take fwiw. |
| Just to make things confusing. ;-) Here is 2 hulls, both have the same shape on the water line, both are paddled with a single paddle. To me they are both canoes, others might call one of them a kayak. Gary ![]() ![]()
| Canoe vs kayak bow Thanks for the input. I guess I'm going for a kaynoe or canyak. My two design choices are down to the Wee Lassie (L) or the Rob Roy (R). The Rob Roy has a more angled bow and stern which will allow me to close the ends on the male plug and still be able to remove the boat from the form. I'll then add medium length decks to each end for floatation, storage and to help prevent waves entering the boat. I guess my original question should have been directed more towards performance than function. I'm sure that the angled bow will encounter less resistance then the less angled canoe type bow. Ultimately what I'm looking for is a short, lightweight boat for smaller creeks and ponds that has a low seat, narrow beam to be paddled with a double paddle, and an open cockpit for ease of getting in and out for portages |
| scrumptious canoes in the pictures. Either of the designs that you mention are elegant examples of a minimal decked canoe. Both are pretty narrow and will not take kindly to paddler gymnastics. When one says the word canoe to the non canoeist, the mental picture is a double ended boat with crescent shaped ends. Similar to the ones we supposed were used by Ojibway and other native american tribes. I suspect that the shape of the ends were more a matter of building facility than of hydrodynamics. The native americans did not have epoxy and had to rely on rawhide lacing and beeswax or pitch sealants. A laced end would last a bit longer when the top terminal end curved back toward the middle of the boat. You are talking about more modern shapes that do, in fact, give some consideration to lumpy water. Sea kayaks often have long overhands that are helpful in lifting the bow or stern when encountering a wave. Go fast kayaks will have plumb ends to maximize waterlines. For general purpose or exploration types, such as Rob Roy, the ends taper a little bit and the forefoot is rounded. That is probably there to facilitate movement over objects that may be encountered in the water. Weeds, logs, and in my Florida case alligators. If you are going to build a plug (male mould) then you have the boat built already. Why not just use it that way and have a boat that is similar to the pretty pictures? You may , or may not, save a little weight with kevlar but not enough to get excited about. Of course if you intend to do long portages, every pound counts. |
| Nice to know. |
| Windage - dont forget about windage - it affects canoes very much, and you would want as low a bow profile as possible if you are going anywhere near exposed waters. |
| Here you will find an enormous amount of information about canoes. It dates from a time when people were very serious about canoes. Consider it a free education. http://dragonflycanoe.com/stephens/ I will 2nd the poster who cautioned about the use of Kevlar, it is expensive and a bitch to work with. You can build very strong light weight canoes/kayaks using wood strip, lapstrake, or skin on frame construction. If you have questions I would like to help, this is a subject I have a passion for. Gary ![]()
| here are some canoes we manufacture and sell. The shape is typically to South Africa and are flat bottomed. First pic of bare hull sans deck and you can see the flat floor. Pic two shows two types I do - the smaller one with the two "hollows" at the back is favoured by fisherman and they put the lines and bait/feed into those rowing lines into the water. The red one is the larger one and two seater and has a little rocker in the hull. Third pic shows my old lady and grandson playing in a smaller canoe ![]() Kayaks are quite distinctive from canoes over here as the posted drawings clearly shows.
| If weight is a concern, you might want to take a look at the GA Boats website They major on canoes, and have some kayak patterns. There are (adapted) versions of both the Rob Roy, and the Wee Lassie. They are exceptionally beautiful, and exceptionally light, but sacrifice some durability: You wouldn't want to be sliding over rocks in rapids with one, I suspect. They do use some exotic materials, which are supplied in a partial kit (no timber) and recommend steam bending for the frames. |
__________________ Wherever there is a channel for water, there is a road for the canoe. Henry David Thoreau |
| The GA Boats Snowshoe12 has a beam of 28", a 10" side, and weighs just 13lbs. (according to spec.) However, from what you say about the rivers, I expect it would be a non starter! |
| Looking for Canoe and Kayak Molds | MntFisher | Boat Molds | 4 | 12-28-2011 05:43 PM |
| kayak/canoe outrigger issue | fabrice | Multihulls | 8 | 04-02-2010 02:42 PM |
| Best material for kayak/canoe | joebagodonuts | Materials | 15 | 06-03-2008 04:53 AM |
| Canoe and Kayak Molds | mikew | Boat Molds | 4 | 09-05-2007 03:32 PM |
| looking for rubber/nylon kayak canoe handles | Jmooredesigns | Materials | 1 | 09-05-2004 12:03 PM |
