| a canoe rigging ? for those in the know... I am midway through building a sailing canoe. The plans are calling for a 10 1/2 ft mast and a 50 sq/ft gaff rigged sail. I am free to mess around and I like the idea of more sale but dont want to tack on much more weight. Im also pretty certain I am going to put an outriggor on. How about moving the mast(unstayed sticking in a hole through the deck) to the back of the boat and running a small genoa, w/roller furler so as to be able to quickly reef, as the main. This would be a tacking outriggor. What does anyone think of that? Am I giving up something? How big could I make the sail? Is it a sail that should go to a sailmaker? |
| Have you seen pics/thread on Fanie's tri that had this rig? Interesting and though not 100% successful - he definately going on with the concept with future boats. |
| I looked him up but just saw the Catamaran. I'd like to see the link if you have it handy. Thanks |
| Try aftmast rigs or mainstaysail - or ask him, sorry cant remember exact thread title. Worked ok except for keeping the stay tight enough. |
| Let us be practical even if it disappoints us. Too much sail on a canoe is going to spoil your day. The conventional canoe hull has a finite limit of speed. That is to say that doubling the sail area will not necessarily double your speed. What it will do is make the canoe a real handful. Way back in the day it was not unusual for racing canoes to split the rig into a cat ketch configuration. That kind of rig was fairly manageable. International 10 meter canoes, which do not look at all like the general perception of a canoe, does frequently use a main with a jib. The jib is more blade than genoa. The IC is one of the fastest small monohulls you can find, but it ain't a canoe and it uses a hiking plank and considerable skipper skill to keep it right side up. Go with the plans and rig the boat accordingly. |
| Probably right.... but check this out anyway - www.faze.co.za/little%20Tri/little%20Tri.html |
| Sorry Alex, the last page is here - http://www.faze.co.za/Little%20Tri/L...20Tri%204.html There were some other changes and experiments I did. If you have a small sail in mild wind you can handle it by hand. The little tri had only 12m^2 sail area but when the wind was up 30+km/hr the sail lifted my 100kg clear out of the hull and put me on the tramp, you need a proper cleat and a double pulley ratio. I added a boom to see how well that would work and it made it a lot easier to keep the foot of the sail streight. If you're interested I can put up more pictures. The lift in the sail keeps the tri from heeling, even in a stiff wind there is very little heel. I suspect the daggerboard should be more foreward a bit, in high winds the lift of the sail keeps you from turning to wind. The sailing setup is really easy to handle. I never added an auto tacking thing which would have been very nice. Personally I'm happy with what I experienced. The harder the wind the better it goes too, the tri not the best shaped hull for speed as it was. I sold all my boats, cannot work outside at nigh due to too many criminals roaming the area. My bigger boat goes a lot slower than I anticipated mainly because I cannot work outside. No space inside, but I'm working on it. Being boatless is really shitty, I become pannicy whenever a cload appears on the horizon ![]()
| Thanks for the link, that was what I was thinking. I don't have that king of room for rigging though. Oh well. |
| Rigging a sailing canoe | MastMonkey | Multihulls | 8 | 11-24-2009 06:44 AM |
| Standing rigging replacement. Synthetic rigging | bulk-head | Boat Design | 4 | 07-26-2009 06:59 AM |
| Rigging Geometry | abindoff | Sailboats | 4 | 03-22-2006 04:57 PM |
| Running rigging? | trimarandan | Sailboats | 4 | 11-19-2005 05:48 PM |
| rigging tension | Lew Morris | Sailboats | 1 | 09-27-2001 08:18 PM |
