| Canal boat plans??? I'm looking for plans for a C canal or Dutch barge in 13-15M range Yhanks Ted |
| Close, but maybe not quite there http://www.boatplans.dk/mo-tug-40.asp
__________________ Matt - JEM Watercraft |
| Thanks. The accomodations are fine. The air draft is too high as is the water draft. To clear bridges the air draft needs to be less than 7'. water draft should be no more than 2'6". Wonder why, with all the thousands of plans out there, that no one is designing canal or Dutch barges for home builders? Thanks anyway. Ted ![]() |
| How 'bout this one? ![]() If big, then look around their site - plenty more to choose from http://www.bransonboats.com/katherine_db.asp Steve HTH |
| Thanks. I didn't know Mr. Branson had a site. I knew he designed for SteelKit in Wales. What kills me here is 2 things. The rate of exchange and shipping costs. That's why the search fo plans. Still... it would be nice to have everything precut, blasted & primered. To be fair, I guess that all has to be figured in. Upon reading, they don't make it clear if they do the bending & rolling. My mouth is watering, Thanks again! ![]() |
| Euroship Euroship in Holland sells steel kits and custum build canal boats. I'm sure that if you contact them they will sell you plans as well. http://www.euroshipservices.nl/english/ |
| Very good! I never would have found this one. Google just passed it by. As usual, I have champagne tastes & a beer budjet when it comes to buying a welded hull. I will ask about plans on a couple that fit my budhet. |
| Drunken wife... Hello... My wife is British... I always buy up as many canal boat mags when we 'go over'... When the two of us sober up I can post some direct links from the classifieds of same... Respond here or Email me - because tommorow is another day - and I can only remember most things by the hour... Cheers... SH. |
| Hello, Have you thought about buying the DXF cutting files and getting a kit cut locally to you? Lots of accurate plasma profileing companies around. Building notes etc would be supplied and free advice supplied. Building using highly accurate pre-cut plate much lower cost than traditional methods. Just think how many man hours involved in lofting and hand cutting the hundreds of components that make up a steel shell? Hard graft! A typical design and DXF cutting file around £2,000, plus of course the cost of your local cutting company. The job becomes an assembly job, both quick and accurate- also rewarding as you see major progress every day! |
| european style canal barge plans | Cory | Boat Design | 8 | 10-09-2009 06:25 AM |
| Design of canal boats | Tadworth | Boat Design | 4 | 08-19-2005 01:53 PM |
| Canal workboats design | Tadworth | Boat Design | 0 | 01-11-2005 11:01 AM |
| Need boat plans (please help) | EMporto | Boat Design | 1 | 11-22-2004 07:25 PM |
| Designing the next canal boat... | olley8 | Boat Design | 1 | 10-25-2004 05:27 PM |
