  #151
Old 11-05-2010, 09:56 PM
tugboat's Avatar
tugboat tugboat is offline
insert cheesy line here
Rep: 109 Posts: 684
Originally Posted by MikeJohns View Post
Tugboat.
I think that design could easily be altered to lose the curves and add some chines , It would be easy to plate up for you and you'd hardly notice the difference afloat. That vessel shape is suitable for a reasonably easy chine conversion. Maybe a little less topside curvature and a single chine . If that was all that stood between you using ferro cement or it's direct strength equivalent Ferr-A-Light then I wouldn't hesitate. :-)
Now there is one use of ferrocement that is worth mentioning (considering your fetish for goo) and that was to take an old steel hull sand blast class 3 minimum, weld studs and mesh and plaster with a good rich pozzolanic mortar (no paint). Some commercial vessels in survey here had this done apparently very successfully but I had no direct involvement. But you still need to descale and treat the inside and that's nearly always where the holes come from.
hmmm--- not a bad idea--ok you know i like fer-a-lite.
could this work too? in essence your talking about using the steel hull for a mold and keeping the mold in the hull?? there is that old rusted hull at the shipyard--5000.00 denarius! but need replating sandblasting and...well its a mess...
I'm Master Mariner first! boatbuilder second!
  #152
Old 11-09-2010, 07:25 AM
tugboat's Avatar
Rep: 109 Posts: 684
one thing people say often about FC is that its labour intensive--but l'd be willing to bet that a large steel boat would be nearly as labour intensive as a FC build...if not more...with all the welding grinding, fitting etc...of course a mold method for fc is not all that labour intensive if you use a staple gun...
Mike--one question I have for you is- back in the day-- and even now, is arc welding smaw, still the best way to go for a heavy displacement steel boat or is a flux core say 90 amp or even a 230 outfit flux core the way to go?
  #153
Old 11-09-2010, 03:53 PM
MikeJohns MikeJohns is online now
Rep: 1729 Posts: 2,459
I prefer MIG, It's so easy . I wouldn't use flux cored, its expensive and it's not as clean. MIG is the cheapest too, here a spool 15kg of class approved wire is around $30 then add the gas. You can weld with straight CO2 which is sometimes even better for the amateur to achieve good depth to the weld. I know people who get CO2 for 1/4 the price of the argon mixes. It does spatter more. You can vary the ratios of Argon and CO2 for different weld characteristics too.
I'd suggest PM Murielle (M&M Ovenden) or Wynand (WynandN) They will give you better advice than I can.
[Edit added.......]
As for labor intensive. That depends on the design. A design incorporating simple surfaces and easily fabricated frames has a much faster build than a round rolled hullform.
The labor for FC is surprisingly crippling. The build time has more to with the number of bits you have to cut accurately and position accurately and fasten than the size of the boat. There are lots of things that get overlooked, on a FC hull they are a real pain to build.
A chined steel design (with well defined frames) from the designer would be much faster than FC but then it's much faster then a rolled plate hull built from offsets too.
Mike Johns.
  #154
Old 11-09-2010, 04:14 PM
pdwiley pdwiley is offline
Rep: 531 Posts: 489
No way is steel building as slow as FC. Even if it was close, it's still heaps stronger. Tom Colvin says building in FC is 2X as long as any other medium. You do not know more about building boats than Tom so please don't fantasise.
WRT welding methods, you have to consider your circumstances. If you are building outdoors then how are you going to provide shielding for a MIG welder using gas?
Cost wise, I'd say that MIG using solid wire and CO2/Argon shielding is cheapest & fastest. Flux cored MIG is very expensive. I paid $115 for a 5 kg spool of flux cored vs $32 for a 15kg spool of solid 0.9mm wire.
I used a stick welder for all the root runs because I wanted to know that they were sound. You can have problems with MIG much more easily than stick in getting good fusion.
The small MIG welders are IMO useless for serious work. The guns aren't up to continuous welding and the feed mechanisms are feeble. They're fine for light structural welds on RHS, angle and the like. This based on a very small sample I might add so there may be small MIG welders that are quality items but they still have small duty cycles.
I recently bought myself a new MIG welder. It has a 250A output with a 60% duty cycle at that output. It has geared drive rollers. I've put about 5 kg of solid wire through it so far and I'm happy with it. I could also show you one weld with incomplete fusion where I welded a lifting tab onto plate. When I later broke that tab free it was obvious that at the start of the weld I hadn't gotten full fusion with the plate. Sure, this is a reflection on my technique but the weld looked fine.
Lots more info on steel boat building in the steel boat area.
PDW - currently 'enjoying' travels and a break from boat building...
  #155
Old 11-09-2010, 06:07 PM
Tad's Avatar
Tad Tad is offline
Yacht Designer
Rep: 2037 Posts: 1,719
This is a fairly complete document of ferro construction including some discussion of man hours required......on the order of 50-60m/hrs per square metre of shell (non-professional crew). With training and experience that drops, but still not as fast as steel construction.
http://www.fao.org/docrep/003/v9468e/v9468e00.htm
If Tom figures steel is half the man/hours of FC, then NC steel will be 30% the man hours.....I assume chined rather than round bottom form.
  #156
Old 11-10-2010, 08:49 AM
tugboat's Avatar
Rep: 109 Posts: 684
hmmm --seems i was a bit off on that estimate for sure...
  #157
Old 11-27-2010, 09:27 AM
tugboat's Avatar
Rep: 109 Posts: 684
you mean this?: the only other thing i could do since i cannot afford 1/4 inch plate, AND rolled(would it even need to be rolled?- coudn't it be strip planked or clinker style?) is to buy 3/16 plate and ballast it a little more...
i think its self evident what i meant by that..and not anyweher did i say I cannot afford to build a boat...i meant that i cant afford commercial operations to build it...as im sure few can...when i went to the steel dealer--they wanted to nest it out...thast about the cost of the hull alone--the reason people build hulls isnt about getting what they want--its about saving money since you CAN just build as you go and dont need the outlay of 25 000 outright--plus interest on a loan and mayeb some of you are like me and hate banks and will do anything to make them less powerful including NOT getting loans...or paying more than i have to to build it...Im not rich but im able to do what i need...im done with the finances issues...
edit:
actually it is also totally about getting the exact boat you want too!
Mini Tug Docker Option One 5 02-28-2008 01:33 PM
3D Max tug Bassoom Software 2 06-11-2005 08:38 AM
Steel plate thickness Ron Cook Metal Boat Building 10 03-05-2005 03:39 PM
Tug Trouble jfblouin Open Discussion: All Things Boats & Boating 1 01-27-2005 10:42 PM
Steel plate Thickness LowcountryData Sailboats 29 11-30-2004 03:17 PM
