| Calculation of Coeficient of wave resistace-Planing hull Hey Everyone, I have to calculation Design loads for a planing vessel which inturn requires Cw- coeficient of wave reisitance to be calculated. I searched through many books including PNA-vol2, things were not fruitful. Can some one help me up plsease .Anil |
| Most methods for planing boats calculate resistance in total and do not attempt to seperate Cw from Cf due to the intrinsic difficulty in doing that for a dynamicly supported hull. Is there a special reason you need Cw, such as wake field calculation? There are other methods out there for far field wake evaluation.
__________________ A vessel is nothing but a bunch of opinions and compromises held together by the faith of the builders and engineers that they did it correctly. Therefor the only thing a Naval Architect has to sell is his opinion. Last edited by jehardiman : 03-06-2010 at 01:11 PM. Reason: sticking e key |
| Thanks for ur reply Sir, Actually i am calculating Design loads for a high speed vessel using DNV ,where for the calcualtion of Longitudinal acceleration and the forth coming pressure the value of Cw(i.e Coeficient of wave resistance) is essential. Could there be any formula to calculated it?????? |
| Are you sure that Cw means wave making resistance? Normaly, logitudinal load for high speed craft is calculated by maximum speed (i.e. total slamming load).
__________________ A vessel is nothing but a bunch of opinions and compromises held together by the faith of the builders and engineers that they did it correctly. Therefor the only thing a Naval Architect has to sell is his opinion. |
| Ya its the wave coefficient-Cw and i got the formula too, it was there in the Classification rule book Thanks for everything sir![]() |
| Formulas for Coefficient of wave resistace | Anil@heisco | Powerboats | 0 | 03-06-2010 12:31 AM |
| Power/Resistance Calculation for Planing V-Hull & Fuel/Engine Required | Kapitan_Raider | Outboards | 24 | 11-26-2008 04:34 AM |
| Planing bow hull and getting over the bow wave hump | kach22i | Boat Design | 2 | 04-03-2007 03:51 PM |
| Cat / Tri dis-planing / wave piecing hull design | llamalookout | Multihulls | 1 | 04-17-2006 11:19 PM |
| Calculation of wave resistance and potential flow. | yipster | Software | 12 | 03-17-2004 08:59 PM |
