| calculating planing surface area I'd like to build a new sailboard with a skiff-like bow (vertical stem). I've written the following articles about my concept: http://www.lbwindsurfing.com/raceboa...eboard-design/ http://www.lbwindsurfing.com/raceboa...oard-design-2/ I'd like to do some calculations on the surface area required to support various weights (while the board is on the plane), but it's been 20 years since I studied fluid dynamics. Can anyone help with the formula to do such calculations? |
| Jim Drake These papers should help-"Drake 2" has the formulas for calculating planing area:
| thanks for this feedback - it is most helpful. Some questions: 1. The formulas to calculate the lift from the planing surface - how do these compare to the formulas for other non-sailboard hulls? 2. Where can I obtain a copy of the figures listed in teh first document? |
| 1) I don't know-this was all I needed-and I haven't worked with it yet. There are MANY threads on this forum about planing....Drakes formulas are a bit simplified for the case of a nearly flat board...The simplest way to proceed is to watch and measure actual windsurfers. Get the exact weights, a Davis windmeter and preferably a GPS speedometer and you can get a pretty accurate idea of what is required in terms of planing area on a board. I would use that info as your #1 reference and back it up with Drakes formulas. 2) You could try e-mailing Jim Drake-his e-mail address is at the end of the document. He has not responded to my e-mail.
| Wetted Surface Area? | naupigos_gr | Boat Design | 4 | 02-05-2009 03:42 PM |
| Heat Exchanger Surface Area | Jellyfish84 | Inboards | 0 | 02-04-2009 08:57 PM |
| Calculating planing Velocity | jamesflett | Boat Design | 55 | 01-06-2009 04:26 PM |
| Rhino - calculating the surface | Maciej | Software | 7 | 06-07-2005 01:01 AM |
| Significance of keel surface area | miked12 | Sailboats | 2 | 11-21-2002 11:47 AM |
