| calculating GZ Can someone please explain to me the steps that are required to calculate GZ. I'm trying to produce a righting arm curve to see if my class project is stable at angles 0-80 degrees. Thanks |
| First... Do you know how to calculate B, G, Envelope Volume, Tank volumes, Iwp, I transvers tank, KG, KB, and BM for any arbitrary waterplane, tank condition, and angle of heel? Otherwise what I will tell you won't make much sense. |
| For convetional shapes , its a lengthy process. We need to find equilibrium water plane for each angle of inclination and corresponding water plane area,Moment of Inertia & Volume of displacement. Then follow the basic equations ( BM=Transverse Moment of inertia of water plane / Volume of displacement.KM = KB+BM, KN = KM X Sin(Heel angle), GZ=KN-KG sin(theta) etc) to obtain GZ for particular loading condition / draft. PNACS@hotmail.com |
| PNACS, I have all the values that I need except KN. I'm not sure what the X value is in the formula KN=KM X Sin(theta). I'm using GHS for the first time so I'm learning the capabilities of the program. Is there a command that will give me the GZ values in GHS. Thanks |
| First tell me, Have you made vessel hull model in GHS? |
| Yes I have imported the rhino model into GHS. I also have added tanks and a skeg using the part marker in GHS. Thanks |
| Once model is defined, Obtaining GZ for a particular draft / loading condition is simple. start GHS, then read the model using command - read <model file name> If u need to find GZ at a particular draft, say 3.0 meter and KG=5 meters. draft = 3.0 VCG= 5 meters solve weight RA 0,10,20,30,40,50,60,70,80 Above will give you RA (GZ) at specified draft and heel angles. Similarly if you set weight add centroids for a particular condition, u can obtain GZ for the case. Say, Total weight of the vessel is 500, LCG=15.0, TCG=0, VCG=5.0 weight 500,15.0,0,5.0 Solve RA 0,10,20,30,40,50,60,70,80 Will ve you GZ values. Read GZ user Reference manual for details |
| GZ GM Cb Cp and other | yipster | Boat Design | 22 | 07-21-2006 08:15 PM |
| GZ curve | ivansalasj | Sailboats | 7 | 02-23-2005 01:51 PM |
| calculating laminate thickness | dionysis | Materials | 21 | 11-05-2004 03:54 AM |
| calculating laminate thickness | dionysis | Boat Design | 11 | 09-06-2004 02:05 AM |
| calculating displacement | 8knots | Boat Design | 2 | 03-21-2002 02:57 AM |
