Old 01-24-2012, 12:16 PM
hospadar hospadar is offline
Rep: 30 Posts: 46
Calculating bilge board/keel area
I'm planning my new small boat after the untimely demise of my ill-fated first boat (Hull shape for simple sailing scow)
This time I'm thinking to build something like a PD Goose, which is basically a 12' long PD racer (a boxy 4' x 12' scow type boat).
I'd really like to use bilge boards or some sort of fixed keel instead of a dagger/center/lee board. The reasons for this are:
a) less separate parts/moving parts to haul around/maintain/mess with while sailing
b) acceptable in shallow areas (most of my boating is inland lakes)
c) I don't really care about sailing performance all that much, just needs to work
d) no trunk in the middle of the boat
The boards will probably look something a little like this: http://www.pdracer.com/keel/195.jpg (perhaps not full-length, but they will just be part of the sides extended below the bottom of the hull)
My question pertains to calculating the area and placement of the boards, I assume the sail-area-to-underwater-foil area calculations I'd use for a daggerboard or leeboard still apply to bilgeboards, or will it be different since bilge boards are so low aspect? How will those calculations change because I have two boards (one on each chine) instead of a single board (should I just split the area between the boards?). Would the length of the boards matter all that much (the difference between full-length or 2/3 or 1/2 or 1/3)?
I'm pretty sure I could just wing it and it would work OK for my little boat, but if there's a better way, I'd be interested to hear about it.
Also, worst case scenario, the bilge boards suck and I hate them, I chop em off and use a leeboard, no real loss there.
Old 01-24-2012, 12:19 PM
Rep: 30 Posts: 46
I just had another thought, kick up centerboard style board where the trunk is built into one or both of the full length side airboxes. Little more work than the bilge boards but probably better performance.
calculating planing surface area yagon Boat Design 3 10-26-2010 07:38 AM
Rusty bilge/keel area idpnd Metal Boat Building 4 09-26-2009 06:25 AM
Piggyback: Bilge Keel threads lewisboats Sailboats 6 07-28-2009 12:44 PM
Catamaran keel area martinchaplin Multihulls 15 08-25-2008 09:52 AM
Keel / centerboard area ? fcfc Sailboats 1 11-08-2005 05:22 PM
