Old 03-08-2004, 03:41 PM
sroberts sroberts is offline
Calc centerboard length
I am in the process of scaling-down a sailboat design by 10%. I am able to find info for calculating things like required spar dimensions, but have not found info on determining the required dimensions for the centerboard. Is there a formula for this or can I just reduce the original dimensions by 10%?
Thanks in advance for any assistance,
Steven
Old 10-06-2004, 08:09 AM
Rep: 66 Posts: 640
Steven
Steven,
Scaling down (or up) a vessel is not as simple as that. When scaling lenghts, areas get scaled almost twice the ratio and volumes three times. As weight, stability, buoyancy, etc. are linked to al these parameters scaling can be dangers without checking afterwards.
In 'principals of yachtdesign' there are two tables on conversion of size, to give you some guidence. Please find them attached.
Scaling01 is proportions versus size
Scaling02 is Prelim. dimensionless ratios
But please check your stability, freeboard/draft etc. before you start to build!
Good luck with rescaling!
Dutch Peter
How to build a Kick-Up Centerboard and Rudder Free Pirate Boatbuilding 10 07-17-2005 08:49 PM
fiberglass roll; determining length by weight and width? GrantC Materials 5 03-07-2005 08:07 AM
Can I make Centerboard and Rudder like this? dougworm Fiberglass and Composite Boat Building 5 12-09-2004 10:55 AM
What Length? fisherman Powerboats 2 05-16-2004 11:29 AM
C&C 32' Centerboard Model Tallsailor Boat Design 2 05-11-2004 06:54 PM
