| View Poll Results: Input device(s) of choice used in CAD for boat design. | |||
| Mouse | | 24 | 80.00% |
| Trackpad | | 0 | 0% |
| Tablet & Pen | | 1 | 3.33% |
| Scan Hand Drawing for Conversion to Cad Files | | 0 | 0% |
| Combination of two or more of the above ... please explain. | | 2 | 6.67% |
| Other ... please explain | | 3 | 10.00% |
| Voters: 30. You may not vote on this poll | |||
| CAD..for those using CAD in their design process For those using a CAD package in the design of boats .. (2D,3D, and modelling)... Are you drawing predominantly with a mouse, trackpad, or pen & tablet? Are you scanning a hand drawing, and using your software to convert this image to useable CAD files? If you please, respond in the poll, AND add your specific thoughts and comments to the thread below. For example, if using a tablet... which one, specifically? For those using a combination of these input devices, would you please describe your typical workflow methods? Thanks for all thoughts. Robert |
| Inside the CAD program I use a combination of mouse, and command line commands to work on drawings. The hull shape is imported from Hullform, not designed within the CAD drawing system. I'm an amateur in that I don't do this for a living. I learned mechanical drawing in college and use the same methods when working with paper or software. It sure is nice to have all 3 views get updated when any view is changed ![]() I'm sure that if I had started with a CAD program I would draw differentially, but I don't do anything with CAD that I could not do on paper.
__________________ Proud supporter of The Far Kurnell Cat Racing Team I have not failed. I've just found 10,000 ways that won't work. - Thomas A. Edison |
| Just the mouse, a scanned file is used only if i have to |
| I think that the method might also depend on the intent. Is the boat a project that you intend to build or create plans to offer to the public? Is a great amount of accuracy required? Is it the reproduction of an existing design? Or, are you building a "model"? What is the source of information on the hull? If you have a lines plan, it can be digitized(scanned) and brought directly into a CAD package. You can trace the lines with the mouse and move them around to establish the loft path for the hull. In doing it this way, you are depending on the designer to draw the hull fair. In any event, should you actually be building the craft, it should be lofted full size anyways. The problem with designing or drawing directly into a CAD package is that if there is not a hull design module for the package, there is no guarantee that you will build/draw a fair hull and plus it's a real bear to create a hull in a straight CAD program. If your trying to recreate an existing design, create a data set from the table of offsets (build a table of offsets from the lines plan if you don't have the table) that can be imported into a hulldesign platform (Freeship for instance). This will give you a set of control curves that the hull can be built around. If you are creating your own design, create it directly within a hull design package. The hull design software will also return a variety information about your design that is immediately useful to know and can be used down the line for other calculations. Once you are comfortable with the hull, it can be exported to your CAD software for furthur developement. Like RHough I don't do this professionally. I'm a hobbyist and do it mostly for the mental stimulation. I've spend time as a mechanical designer and done some work as a 3D modeler. Showing my age, I took manual drafting the last year it was offer at the local university before they switched to computer drafting. In regard to input device, I use the mouse, but if I know the exact dimension, I'll keyboard it. Unfortunately, there is not one single product that will do the whole job (I don't know of it anyways) and if there was, I'm afraid it would be quite costly. Especially for the hobbyist. Regards
__________________ LP ---------- God bless the open minded people of the world. LP |
| I like a wacom intuous tablet and the wacom 5-button 4d mouse (use the pen for photoshop, but the tablet mouse for cad.) I like this because the position is absolute on the tablet so after a while you can hit a given toolbar button without looking. (on the other hand, I started swearing by tablets when mice still had balls.) |
| Mouse and keyboard in AutoCAD/IntelliCAD. Never use the mouse to give a fixed point or distance, use the keyboard when you need accuracy. |
| Wacom tablet for CAD en sketching a spaceball (the classic models 3003C) for manipulating the model: http://www.3dconnexion.com/products/3a2.php I don't know what to do without it ;-)
__________________ |
| work with a big mouse, have to get myself a good pen tho as magic markers all dryed out ![]() |
| same problem over here.. copics and tria's need special care these days ;-)
| SpaceMouse A SpaceMouse is rather cool to work with but it takes some time to get use to it. And start with slow or medium speed at first http://www.cs-software.com/hardware/...pacemouse.html Hans |
| I use a mouse and a 3-d spaceball. If you work regularly with 3D packages, then this is a very powerful tool that saves vast amounts of time, not to mention helps reduce the possibility of carpel tunnel.
__________________ http://www.eliboat.com |
| I use the keyboard and mouse in autocad and freeship. |
| Vacuum Infusion Process | roko | Fiberglass and Composite Boat Building | 5 | 06-01-2005 01:06 PM |
| simulate infusion process | pdesign | Software | 1 | 06-02-2004 04:10 AM |
| Powering estimation 1 days process...USD 200 | fadly2000 | Services & Employment | 0 | 07-02-2001 01:45 AM |
