Old 03-31-2011, 01:43 PM
frank smith frank smith is offline
Rep: 169 Posts: 756
buttock angle ?
I notice a great variation in buttock angle of sail boats . It look as though there are trends that change with time. There is the obvious consideration of making a smooth transition from midships section to the stern . And this will change with the water plane shape and draft.
What are some of the things that effect
the buttock angle.
Thanks Frank
Old 03-31-2011, 02:48 PM
TeddyDiver's Avatar
Gollywobbler
Rep: 1475 Posts: 2,268
Fr number and Cb for instance.. Smaller buttock angles are typical for semiplanning and planning hulls and then also the other "numbers" related to speed of particular design change accordingly..
Old 03-31-2011, 04:22 PM
Rep: 169 Posts: 756
So a shallow draft hull with a high Cp will end up with a steep buttock angle ,
unless the aft sections are very wide ?
Old 03-31-2011, 06:29 PM
daiquiri's Avatar
daiquiri daiquiri is offline
Engineering and Design
Rep: 2981 Posts: 3,511
You also have to consider that, besides being determined by purely hydrodynamic or internal accomodation considerations, trends in sailboat hull shapes have been heavily influenced through years by various handicap rating systems and by designers' efforts to carve a maximum advantage out of them.
You can find a nice summary of how these rules have changed the shape of hulls from 19th century to present days in this site: http://www.sailtexas.com/handicaparticle.html
Old 03-31-2011, 10:04 PM
Rep: 169 Posts: 756
daiquiri , thank for the link. My reason for the question is an interest in a shallow hull with high initial form stability , like the junk or barge type boat. In particular I am looking at the work of Bolger , Griffiths , Hunt, and also the presto type sharpie.
Old 03-31-2011, 10:23 PM
Rep: 1909 Posts: 1,753
Where are you looking to measure the buttock angle?....
A barge could be said to have low buttock angle or a high buttock angle depending on where you take the measurement.
As Daiquiri said, buttock angles have much more to do with the intended use of the hull than with the age of the hull. So a low capacity shallow water sharpie may have a 2-4 degree buttock angle at the aft waterline, where as a high capacity canal boat of the same length may have a 90 degree one at the aft waterline.
trim angle jollyricard Boat Design 2 06-10-2010 05:41 AM
Steps angle Flysafe Boat Design 0 10-20-2009 02:02 PM
Skid Fin Angle or not to Angle? dcrummett Powerboats 2 06-11-2008 04:29 PM
two right angle bevel toussy Inboards 1 04-07-2007 12:31 PM
Relationship between angle of attack of keel and heel angle stelios Sailboats 9 05-29-2006 03:14 PM
