Old 08-16-2006, 06:32 AM
djwkd's Avatar
djwkd djwkd is offline
Rep: 51 Posts: 380
Bulkheads
what is a bulkhead and where is it located?
Old 08-16-2006, 07:43 AM
Figgy's Avatar
Figgy Figgy is offline
Rep: 88 Posts: 315
From Wikipedia:
A bulkhead is an upright wall within the hull of a ship. Bulkheads in a ship serve several purposes: They increase the structural rigidity of the vessel, divide functional areas into rooms and create watertight compartments that can contain water in the case of a hull breach or other leak.
The word bulki meant "cargo" in Old Norse. Sometime in the 15th century sailors and builders realized that walls within a vessel would prevent cargo from shifting during passage. In shipbuilding, any vertical panel was called a "head." So walls installed abeam (side-to-side) in a vessel's hull were called "bulkheads." Now, by extension, the term applies to every vertical panel aboardship, except for the hull itself.
Imagination is more important than knowledge.
-Einstein
Old 08-17-2006, 05:52 AM
djwkd's Avatar
Rep: 51 Posts: 380
thanks
Are Bulkheads Necessary? LBG Metal Boat Building 13 08-24-2006 08:48 PM
ply bulkheads mattoc Materials 6 08-17-2006 08:40 AM
How to trace and cut bulkheads ath Sailboats 18 06-10-2005 02:43 AM
Adding bulkheads Ok J Fiberglass and Composite Boat Building 5 05-03-2005 11:45 AM
Vacuum bagging bulkheads tbot Fiberglass and Composite Boat Building 4 03-11-2005 07:00 AM
