Old 08-14-2006, 05:20 PM
tomdeering tomdeering is offline
Rep: 10 Posts: 5
bulkhead placement?
I'm planning a 20 foot plywood stitch and glue pontoon boat. Something along the lines of this, but longer:
http://www.jemwatercraft.com/pontoon.php
My question is this: When I lengthen the design, how far apart should I place the bulkheads? Is there a rule / formula / guideline for this, or do I build it and find out if it breaks apart?
Left to my own devices, I'd add more bulkheads so that the distance between them is the same as in the original plans.
Any suggestions will be appreciated.
Tom
Old 08-14-2006, 06:29 PM
ted655's Avatar
ted655 ted655 is offline
Rep: 122 Posts: 641
By changing the length, will you change the thickness of the ply? Those bulkheads are spaced to shape the pontoons as much as for strength. Thickness will matter.
Looks like you could strech the middle by doing exactly what you would do left to yourself and follow their spacing, while shaping the ends as they have designed it.
You are making it longer because??? 'toons are very load sensitive. If adding a cabin or other substanchel weight, you may want to increase all dimentions.
Also, the amount of displacemrnt to material used in 'toons is more than a single hull design. Add the total sq. ft. of ply in those 'toons VS their displasment. Now build a single hull from that same material & check that disp. figure. Wierd huh?
Ted says: If it has tits, tires, or a transom, there's gonna be issues!
Old 08-15-2006, 12:23 PM
Rep: 10 Posts: 5
I don't want to change the load much, I just want a little more space to fish. I figure the boat will draft shallower, but that's not so bad.
I was hoping to still use 1/4 inch ply as specified. I already bought it. :^)
Thanks for pointing out the material used versus displacement. I'll think that over.
Thanks! Tom
Old 08-15-2006, 03:47 PM
ted655's Avatar
Rep: 122 Posts: 641
It looks as if the 2 sections on either side of the center frame are 4'. Then a smaller frame and 2' to a point.
If you add 8' more then I would add it by building 1 more frame the same size as the middle one. add 4' more on either side of the new frame. This gives 4 four foot spaces, leaves the 2 two foot spaces as they are.
So... instead of a taper starting at midpoint, you will have an 8' straight section and then the taper starts. I see no harm in that. IF... you are a "belt AND suspenders" type person, then I would notch the center of all sides of all frames and inset a 1 X 4 stringer for a horizontal rib on all surfaces. The very ends of these need not go to the very ends of the 'toons.
Old 08-15-2006, 04:03 PM
ted655's Avatar
Rep: 122 Posts: 641
Sorry. I can't figure how to edit. It should read, "build 2 more frames".
Old 08-15-2006, 06:05 PM
Rep: 10 Posts: 5
belt and suspenders
Originally Posted by ted655
IF you are a "belt AND suspenders" type person
"Overbuild" is my middle name.
Houw could it miss?
Thanks for your help.
Tom
Rotten Bulkhead - Help!! JoseSanchez Boatbuilding 21 07-03-2006 08:13 PM
Bulkhead: structural or not? Nopollution Boat Design 4 02-21-2006 02:31 PM
bulkhead tabbing dman Fiberglass and Composite Boat Building 1 08-12-2005 06:28 PM
Bulkhead materials and chainplates zaney Sailboats 3 11-11-2004 03:42 PM
bulkhead question 8knots Boat Design 3 05-11-2004 11:15 AM
