Frosty,
Froude numbers are a way of comparing speeds of different sized boats. When you do model tests on an oil tanker, you tow the model down the tow tank at the same Froude number (rather than actual speed) as you expect the full sized tanker to sail at. A 100m tanker at 13kts will have a Fn of 0.213, so a 2m model would be towed at about 1.8kts to get the same froude number. Ignoring viscous effects, the resistance of the model can be scaled to the full size ship, for the same Froude number. You may have heard of 'hull speed', which is often quoted as 1.34*sqrt(length). This is the speed of a boat (in knots) at which the bow wave is the same length as the boat. Going quicker than this increases the length of the bow wave so that the stern is sitting in a trough. The result is that lots more power is needed to go just a little quicker, so 'hull speed' is a practical limit to boat speed. Well, hull speed is closely related to Froude number and in fact a Froude number of 0.4 is the same thing. That is, conventional boats rarely travel at speeds above Fn = 0.4.
Froude number is not related to bulbous bows, per se. Nor is it related to the number of hulls, so catamarns have the same Fn as monohulls. The only difference is that catamarans are not constrained by hull speed becasue the hulls are so slender that the bow wave does not cause much drag. So cats can go above Fn = 0.4.
Bulbous bows act as little boats in front of the big boat, and produce their own bow wave formation. As noted above, bow wave length is related to Froude number, so by carefully selecting a size and shape of bulb, the bulb's bow wave can be made to have troughs where the main hulls bow wave peaks are, cancelling them it out. By removing the bow wave the ship is able to go quicker. However, when travelling at the 'wrong' speed (and hence wrong Froude number) the two bow wave systems will not be exactly out of phase (cancelling each other out), and may instead co-incide, leading to an even bigger bow wave. So bulbs are generally used on ships which travel at a constant, known, speed (Fn), rather than sailing boats whose speed obviously varies with wind strength.
Because catamarans don't produce a particularly large bow wave, using bulbs would not have much effect on speed. Maybe they are on your boat to reduce pitching, there are other ways of doing that besides bulbs.
At 24kts, your boat has a Fn = 1.09, which is pretty high. A non-planing monohull of the same length has a hull speed of less than 9kts (Fn = 0.4).
Cheers,
PI
