| Bulbous Bow Cb Hi Just wondering how you define a ships Cb when a bulbous bow is involved. Cb is usually defined as Cb = V/ (Lwl x Bwl x T) [Volume over Waterline length by Waterline Breadth by Draft] However with a bulbous bow involved your waterline length is shorter than you immersed waterline, hence you have some displacement volume outside of your defined waterline block. so my question is from what length point do you define your "Block" witha bulbous bow? Any help or info appreciated Cheers Nick |
| Volume is volume. What do you think the volume is for the Cb, for a dreadnought destroyer, or a SWATH!!?? The term 'block' in these instances is bit of a misnomer. |
| As Ad Hoc said, volume is volume. Traditionally, a bulb is an appendage, and like rudders and bilge keels is not considered part of the main hull for the volumetric coefficients. So the Cb is defined in the traditional way with the LwL measured from the Fwd Perpendicular, which is placed at the Design Load Waterline, and at this draft the bulb should be submerged. If it isn't submerged, it isn't functioning as a bulb bow. FWIW, I doubt that the additional volume of a traditional bulb bow will change the block more than 0.005. If it does, then it is not a bulb, but part of the main hull.
__________________ A vessel is nothing but a bunch of opinions and compromises held together by the faith of the builders and engineers that they did it correctly. Therefor the only thing a Naval Architect has to sell is his opinion. |
| Bulbous Bow Design | Guest625101138 | Boat Design | 38 | 08-21-2011 05:09 PM |
| I'm conviced an eskimo style upswept split bow acts like a bulbous bow, but | Squidly-Diddly | Boat Design | 4 | 08-23-2009 06:08 PM |
| Bulbous Bow applications | juiceclark | Boat Design | 35 | 04-16-2008 12:57 PM |
| Bulbous bow | Hotel Lima | Boat Design | 1 | 09-09-2007 05:23 PM |
| Bulbous bow on a sailboat | mholguin | Boat Design | 2 | 03-14-2005 06:37 PM |
