Old 08-23-2010, 08:16 PM
Mat-C Mat-C is offline
Rep: 109 Posts: 242
Bulb vs Long WL Length
I'm sure there's no single or simple answer, but that won't stop me from asking the question....
Within the confines of a given length - say 20 metres for arguments sake - which is likely to have the higher displacement speed (or the lower powering requirement) - a vessel with a WL length of 20 metres (ie a vertical bow), or one with a more raked stem, but with a bulb extending to that same 20 metre mark?
All other things being equal, of course.....
Old 08-23-2010, 08:24 PM
apex1
The no bulb...........
Old 08-23-2010, 08:26 PM
Rep: 109 Posts: 242
Hmm... so, it was a simple question afterall !
Longer WL Length rules, then....
Thanks Apex
Old 08-23-2010, 09:10 PM
apex1
And WL is there in all conditions.
A bulb can provide more drag than designed for, in some conditions.
Last edited by apex1 : 08-24-2010 at 09:18 AM. Reason: one should learn typing all words, before posting....
Old 08-24-2010, 08:49 AM
Eric Sponberg's Avatar
Rep: 2547 Posts: 1,426
Actually, you will also have a pronounced effect on hull speed by changing the beam. A narrower boat has less drag than a wider boat. So, for a given length, a narrower boat is better for performance. A narrower boat will not be better for living accommodation, however.
With bulbs, you can get them just right at some speeds, but they might be just wrong at other speeds. And whether a stem is vertical, or inclined with a bulb, or even reversed, may make little difference in efficiency in all weather conditions--it depends on the rest of the hull shape and what the sizes of the waves are. What is the combination of factors that results in the best efficiency? You can't limit the choice only to stem shape and waterline length.
So you are right--there is no simple answer.
Eric
Eric W. Sponberg
Naval Architect
Sponberg Yacht Design Inc.
St. Augustine, Florida
www.sponbergyachtdesign.com
Lead Bulb matalag Boatbuilding 7 06-26-2006 11:10 AM
Bulb Quest Again... Torrey Boat Design 4 06-03-2006 04:21 PM
new bulb keel mod flod Boat Design 8 01-29-2005 11:25 PM
2d to 3d bulb design nico Sailboats 1 03-02-2004 03:51 AM
A Bulb Question 8knots Boat Design 3 01-15-2004 05:43 AM
