| A Bulb Question If designig a hull with a bulb, Can you include the added length it gives you to your waterline length and work your math from this longer WL versus the shorter DWL of where your real waterplane is. I think this would affect your S/L a bit. Any opinions welcome! 8Knots |
wsa -approximate formulas article. if this includes altered wave resistance calculations around hullspeed for bulb bows i'm not so sure of. in 2002 i was fast boating around but once back in the hole faced with a very slow boat, and the hullspeed formula was all i knew at that time! someone told me a cat had a double hullspeed from witch i distilled wrong assumptions. still an amateur, i did learn some things since than on this forum here... |
| Thanks for taking the time to dig up that link Yipster. I went ahead and printed it out for future referance. It seems I have some work to do.......May god have mercy on my brain cell 8 |
| you'l survive, its a lot but the math isnt that hard. i like your original 50' trawler cat and guess you be calculating 2 hulls? cg not to much forward now? i have seen good specs but still like to see a cat hullspeed / power calculation... |
| Hull enlargement question?? | jackason | Boat Design | 3 | 09-09-2005 07:03 PM |
| Retractable bulb keel | brevell | Boat Design | 0 | 05-26-2005 03:40 PM |
| Keel, bulb and rudder design | ivansalasj | Sailboats | 5 | 02-06-2005 11:42 AM |
| keel bulb design - help | garofaloj | Sailboats | 17 | 01-14-2005 11:36 AM |
| Adding a bulb to keel | Laser28 | Sailboats | 27 | 10-22-2004 09:52 AM |
