| Perhaps this may solve all your problems www.youtube.com/SuperHakane
__________________ tomkane |
| paddlewheel |
| Hi every body I have a boat 13m it is a v bottom hull not much at the transom about 12dig dead rice , I want to fix single engine with shaft and prop , I have to make a tunnel to get the propeller clearance question is what is the best rudder position to get the best performance. If I put the rudder blade complete inside the tunnel (rudder blade will not come out from the end transom. Or move the rudder blade to stern so rudder blade will come out of the transom end about half of the rudder. I like to have a an advice. Which option will give good performance when you do reversing. Regards Nirmal -Yemen |
| Building a stern tunnel into an existing aluminum boat The image may give you some ideas this is an improved model with a venturi built into the top half and fins to straighten out the water flow. Tunnels like these work similar to a surface propulsion.
| Help building a 17' long x 50" bottom flat bottom aluminum boat | Loewman | Boat Design | 22 | 11-21-2011 12:31 PM |
| help building aluminum flat bottom | buckshot68 | Metal Boat Building | 5 | 08-27-2011 01:41 PM |
| Flat bottom alluminum boat building ? | spracky | Boat Design | 7 | 01-19-2010 03:37 PM |
| Comparison testing of an Atkin tunnel-stern v-bottom Seabright skiff and another boat | kengrome | Boat Design | 79 | 06-25-2008 05:35 AM |
| Flat Bottom Jet Tunnel | dick stave | Boat Design | 4 | 04-14-2006 01:56 PM |
