Old 09-12-2010, 12:46 PM
zenicman9 zenicman9 is offline
Building a Raft
Hi
I know you probaly get this alot, But we are doing a raft race for chairty,
The raft needs to be able to be light or be able to go down wiers, it needs to hold 6 people and be easy to steer and be quite fast in the water.
We would like if possible to also make it peddle powered but are not to worried if we cannot.
Does anyone have any ideas?
Old 09-12-2010, 01:30 PM
Vulkyn's Avatar
Vulkyn Vulkyn is offline
Rep: 529 Posts: 486
Not sure if those designs might work, but should give some idea's
https://www.boatdesigns.com/Human-Power/departments/8/
http://www.chrisharrison.net/project...ers/index.html
Hopefully a more experienced member would give you more info
The Mummies Dummy guide to boat building stuff!!!
"All of us could take a lesson from the weather. It pays no attention to criticism."
"Learn wisdom when you can its gona help you out some day in your life"
Old 09-12-2010, 01:46 PM
lewisboats's Avatar
Obsessed Member
Rep: 1263 Posts: 1,840
Rafts are inherently not the easiest things to steer. Nor are they fast. They are primarily designed to float with current and not really fast current at that. That being said...a light weight raft could be done with blocks of foam glued together and sandwiched between cheap plywood sheets-thru bolted with some allthread to keep things together and provide some protection for the foam I would go with 6 ft wide and 12 ft long using 2" sheets of foam stacked say 8 deep, 1/4" ply for the top and bottom. Make a large barn door rudder to steer it with and make sure it projects around 6" below the bottom at the deepest but slopes upwards as it goes forward so it slides over things. You want pedal power? mount a bike in the middle, take off the back wheel and mount the sprockets to a shaft and make it a paddle wheeler.
Old 09-12-2010, 03:00 PM
Submarine Tom's Avatar
Mariner
Rep: 937 Posts: 1,941
Simply steer it with differential thrust. One side pedals more than the other.
I believe the term "raft" is being used loosely here...
-Tom
Building a raft alopia Boatbuilding 9 07-27-2011 03:30 AM
Raft/Junk Raft Building djwkd Wiki 5 03-03-2011 10:47 PM
Raft building help! junkrafter Boat Design 20 01-06-2010 05:30 PM
building a raft on $75 Captain Mark Open Discussion: All Things Boats & Boating 70 01-04-2010 04:03 PM
New Raft Building forum!!! djwkd Open Discussion: All Things Boats & Boating 13 01-25-2009 01:22 PM
