| BUILDING A PONTOON BOAT 16 ft need advice :) im not sure if im in the right section but me and my friend desidet to build a pontoon boat we dont know much about boats so were not sure what to make the hulls out of so far we got 3 choises; we can weld aluminium together to form a hull but were not sure how it will work because most hulls are air compressed other method is to take 4-5 barrels and weld them together [and if it will help stuff them with industrial sealing foam the ones they use to make panels with OR we can just use wood and put a fiberglass on top for the engine we think that using a boat motor would be too easy so were thinking of taking any other small motors [lawn mower, go cart, .....] the other thing we want to do is to make the deck come appart for easy transportation make it bolt and unbolt in the middle and make the hulls bolt on and bolt off so far were not sure what to use to waterproof and coat it with so any advice would be much appreciated ![]() and all the pictures are just versions and scrap scetches [the propellers supoust to be way lower |
| I did a seach in the forum and found a link which may give you a head start. Link: http://www.u-fabboats.com/ I found this doing a Google search: http://absolutelyfreeplans.com/Boat%...boat_plans.htm
__________________ George: Architect (land lover type) Hovercraft & Vintage Porsche Owner http://www.boatdesign.net/forums/boa...ect-11973.html |
| thanks a lot |
| Another homemade model - foam? Foam Boats http://www.citylites.com/foamboatplans/ Build The WizCat 130 pontoon deck boat for under $500 Quote:
Of course you will always learn more from a failure of your own. http://www.citylites.com/foamboatpla...building3.html ![]()
| This gets an "A" for the "Cool" factor. http://www.n55.dk/MANUALS/BOAT/BOAT.html ![]() Quote:
http://www.n55.dk/ Click on Manuals.
| ur right that is a weird plan |
| Can anyone advice me on how to waterproof the wood or apply the fiberglass? |
| Do a forum search, plus I know there is information in the links I posted. Also look in this part of the forum: http://boatdesign.net/forums/forumdisplay.php?f=6
| Need advice on a new or used pontoon. | Tasantherus | Open Discussion: All Things Boats & Boating | 5 | 03-13-2008 10:55 PM |
| Building a very cheap Pontoon Boat ? | bernhardusa | Boatbuilding | 4 | 09-17-2007 08:51 AM |
| building a pontoon barge | bscriver | Metal Boat Building | 2 | 06-22-2006 06:03 PM |
| Advice on boat building | zoso | Boatbuilding | 17 | 01-06-2006 09:32 PM |
| Building small pontoon boat. Ideas? | drose | Boat Design | 1 | 07-21-2005 07:02 PM |
