| building "nester" question I am building the David Gerr "nester" dinghy. In the instructions it says "deduct the plank thickness (1/4") and measure the bevel for each frame and transom. The plank thickness deducted at the bow and stern transoms has to be adjusted for their rake. I have drawn the frames and then reduced the size by 1/4"where the 1/4" plywood will be. For the bevel part, do I just measure the angle off the drawings with a bevel square and then transfer it to the frames? What does the last line mean "The plank thickness etc...." Can I not just make the transom 1/4" smaller for the plywood, put it at the correct angle and then sand the wood to put the bevel right? Thanks, Richard |
| Because Nester's bow and stern transoms are raked, the planking thickness to be deducted from the given dimensions is different than it is for the frames. If you draw a close-up profile view of the joint for yourself, you will see how Gerr has picked off the given dimensions and why the planking thickness deduction is different. Using a bevel square to copy the angles from the plans to the actual frames ought to work just fine. Since Nester is an epoxy-taped-chine design, I wouldn't worry too much about getting the fits exactly perfect.
| shouldn't optimized designs be "salt" OR "fresh" water? | Squidly-Diddly | Boat Design | 4 | 09-14-2009 02:17 PM |
| CMD "project Zeus" VS VOLVO "IPS" | gerard baladi | Pod Drives | 13 | 09-10-2007 10:23 PM |
| Boat "workshop" including a "testing tank" | zmfmd | Open Discussion: All Things Boats & Boating | 0 | 08-08-2007 05:43 AM |
| how to's "building a wooden sailboat mast" | fishweed | Wooden Boat Building and Restoration | 8 | 12-23-2006 08:32 AM |
| Drawing for Rhino of "Boat Racing Chair" and "Machine Gun" | Vibtor | Software | 0 | 10-02-2004 03:03 PM |
