| building a mast Does anyone have experience or information on construction building techniques/ plans for Rotating Masts & Wing Masts? Or just masts in general. I've found a little information which I’ve posted http://www.psychosnail.com/blog/post...ing-Masts.aspx but what I’ve got so far is very technical on aerodynamics etc. I'm looking for something more practical. I remember seeing a pdf on building a wooden mast some while back mast but can’t find it again. Thanks!!! ryanonthebeach |
| find a guy named Eric Spoonberg in this thing he seems to be the mast guru B |
| Everything I found said keep weight down up high and use Sitka Spruce in a series of laminations and overlaps. I'm not a sailor man so that is the best I can do. There is other wood, some used in wing spars in airplanes of WW 2 by the british and in the Japanese zero--they used wood from the Princess tree, tight vertical grain, light and very strong. I think they also called it the Kiri tree. Botanical name is Paulownia tree. Don't know what wood the British used in the Mosquito Those planes could pull 3 Gs on their wings at speed. If you used crib framing when you laminate I can't think of anything stronger in wood, using epoxy. Also, you can create 2- 1"x 2" hollow spaces or 1"x1" where in conduit you can run a lighting ground and in the other space you could run 4 hot lines and 4 ground lines seperated by 2" of wood from the lihtning ground. I hate seeing exterior conduits. P.S. lay your conduit in as you build it==much easier. |
| Well, much depends on what you want, materials you'd like to use, the boat, the proposed rig, etc. Can you define a little more about your project needs for us. The very nature of masts and their use, requires a fairly good understanding of the engineering and aerodynamics involved. How else could you develop a structure capable of standing in building wind strengths. |
| Call me and I can answer your questions. Eric (904) 460-9494 St. Augustine, FL
| I saw plans to make a wooden mast of planks/glue in the "Wooden Boat" mag or the "Boat Builder" in the late 80's or early 90's. |
| how to's "building a wooden sailboat mast" | fishweed | Wooden Boat Building and Restoration | 8 | 12-23-2006 08:32 AM |
| Building a Carbon Fibre mast | mojounwin | Boatbuilding | 7 | 10-27-2005 03:40 AM |
| Building a laminated wooden Mast | Dominique | Sailboats | 14 | 06-02-2005 03:34 PM |
| mast design-how do you go upon calculating the effect of the sail on the mast??? | airturb | Sailboats | 34 | 02-21-2005 10:55 AM |
| carbon-epoxy mast building | krobas | Boatbuilding | 0 | 11-08-2002 05:25 AM |
