| Building a better Lifeboat The "Heavy weather capable dingy design" thread posted by zorton got me thinking about one of my pet projects. I've always admired the enclosed rigid lifeboats like the big boats have (see http://www.nme.no/new_equip_pages/new_telb.asp), but I can't fit one on Portager. There is a Canadian company that builds small, 4 and 6 man rigid lifeboats, but they are still much too large for Portager. The inflatable liferafts are less than an optimal alternative since they require annual inspections which make the total cost of ownership much higher than expected. It occurred to me that it should be possible to produce a folding lifeboat based on the folding Kayak technique (see http://www.foldingkayak.com/construction.htm) with a rigid internal skeleton and a waterproof fabric outer skin. Anybody got any good ideas on how to build a better lifeboat? Cheers; Mike Schooley
__________________ Designing "Portager" a transportable passagemaker |
| How about a rigid hull inflatable, which can double as the vessels tender, with a rapid-erection hardtop / shelter...... ......I know, you can just hear it now ..."mine erects faster than yours!...."
| Self Inflating Rugby Ball And I thought it was how long you kept it up that counted! Why didn't somebody tell me!! Sounds like a workable approach, although you might want to store the lid on the RIB to reduce response time. Maybe you could store the lid on the davit and have the ability to launch the RIB either with or without the lid attached? It would also be good if the lid made the RIB self righting. Water ballast in the bilge would help. I had something a little more compact in mind. My concept is football (rugby ball) shaped with 6 panels so the cross section is a hexagon. When deployed, it would be about 8 feet long and 4 feet high. There would be 6 curved ribs running from end to end so that when you release the restraining bands in the middle it would pop open automatically. There would be a water ballast bladder inside for stability arranged so that one rib would be down forming the keel. An inflatable "air mattress" type floor would be on top of the ballast bladder to prevent hypothermal. There would be zippered access panels in the sides and vents in the "roof". When it is collapsed it would be about 6 inches in diameter (150 mm) and 10.75 feet long. Cheers; Mike Schooley
| Steel Boat Building | alaskatrawler | Metal Boat Building | 9 | 09-06-2005 09:43 PM |
| building mold and boat from scratch need help | marbleman | Fiberglass and Composite Boat Building | 6 | 08-08-2005 12:16 PM |
| Building Cats in Brazil | caribmon | Boatbuilding | 5 | 09-04-2004 07:47 AM |
| new free design & building project: YAGO 31' steel origami yawl | yago | Boat Design | 1 | 08-21-2004 01:42 AM |
| Boat Building Courses in Australia | yachtie2k4 | Education | 0 | 07-04-2004 06:00 AM |
