Old 11-20-2009, 11:08 PM
rockfish rockfish is offline
Rep: 10 Posts: 3
budget shallow water boat project
hey yall, just wanted to share my homemade jet project that i made with a screwdriver and a sawzall last winter, i put my kawasaski 650 in a 14ft alum boat. its soley purpose is to fish and access deeper holes in rivers when its shallow 1ft or less. the only problem i have is that the bow plows the water when i try to go faster, so i just cruise it at 1/4 throttle. i have moved all the weight to the back of the boat. i think its when i mated the jetski hull to the boat hull the intake was sucked up bout an inch, but it does 25 mph at 1/4 throttle and gets real good gas milege too. the only thin i got to watch out for is rocks, leaves and other floating debris is ok, it chopps it right out after some throttling. i just carry a long screwdriver for rocks. so far it lasted a season w no water leaks very reliable
Old 11-21-2009, 12:33 AM
narwhal narwhal is offline
Rep: 45 Posts: 68
Good on you, a low budget experiment that has mostly turned out OK, and provides a successful solution to the skinny water problem. What is your investment, in both time and cash?
Old 11-21-2009, 10:02 PM
Rep: 10 Posts: 3
well, i worked on it over the winter on and off till spring and i spent about 150 bucks in materials. the boat i bought for 300 bucks w trailer , and the ski i already had, but prolly worth 800 its a 88 kawi 650. i rebuilt the motor 10 years ago and rode it few times and its been parked ever since. the motor has around 50 hp w stainless steel impeller. the hardest part is to find the right boat, a boat with no center ribline. all in all this boat costs less than a cheapest outboard jet motor only. it performs better as well.
btw. im in mid tn. too, the third pic down is a popular trout river.
Old 11-22-2009, 12:00 AM
Rep: 45 Posts: 68
Is that the Caney Fork below Center Hill Dam?
Old 11-23-2009, 10:44 PM
Rep: 10 Posts: 3
yep, it is.....about 20 rivermiles below the dam. i never go upper river because thers too many waders and cannoe traffic in summer,i dont want to be rude and blast through right in front of them. so i usually fish below bettys to cumberland where the bigger fishes are.
Old 11-23-2009, 11:54 PM
Rep: 45 Posts: 68
I canoed from Dam to Betty's on 9-11 this year w/four friends -- it's a good river for old men like us.
Old 11-24-2009, 10:55 PM
Loafer Loafer is offline
Rep: 10 Posts: 3
nice job rockfish-
have you considered a drop down hydrofoil on the bow for your high speed runs in open water
New Shallow Water Bay Boat design....? Baywolf Boat Design 8 03-04-2008 02:56 PM
shallow water drive for aluminum boat ge1111 Surface Drives 1 09-24-2007 02:37 PM
Shallow water RAO wbouwmans Boat Design 0 10-11-2006 03:11 AM
Shallow water propulsion john zimmerlee Propulsion 9 06-29-2006 07:23 PM
Welded Aluminum Shallow Water Boat dick stave Boat Design 15 03-25-2005 09:36 PM
