Old 11-29-2010, 04:31 PM
tom28571 tom28571 is offline
Rep: 1500 Posts: 1,681
Originally Posted by Mr Efficiency View Post
I have seen outboard powered flattish-bottomed planing hulls that had broaching tendencies modified with skegs on both sides, maybe 3" or so deep, over the last 3 feet of the hull approx., halfway between the centreline and the chine. That avoids interfering with the water flow into the prop that may occur by deepening the central keel. Moving fixed weights aft may not be that helpful, as the "lever arm" working to broach your boat will be lengthened by it. Dragging the centre of lateral resistance back by increasing the underwater profile aft will dampen broaching.
Skegs near the longitudinal position of the prop is going to give ventilation problems in turns whether on center or to the sides. There is a reason that skegs are cut away forward of the transom.
Tom Lathrop
Old 11-29-2010, 04:42 PM
Mr Efficiency Mr Efficiency is offline
Rep: 246 Posts: 710
I wasn't talking near the propellor, Tom, "halfway to the chine" is nearly 2 feet, would be a crazy sort of turn to interfere.....and give cavitation or ventilation problems, with a shortish length skeg out there. It would result in additional drag though, and has to be seen as an original design flaw if added as a result of unsatisfactory handling.
Old 11-29-2010, 04:55 PM
Not sure we are on the same page here. I think, although I have not tried it, that a significantly deep skeg all the way to the transom will still cause turn ventilation problems even if it is 2' off center. In a turn, it will still be in front of the prop as the stern moves sideways.
Tom Lathrop
Old 11-24-2011, 09:27 PM
skypoke skypoke is offline
Rep: 60 Posts: 39
Eli,Yep, I still have the cat, it's worked out really well. We've had it out 100+ miles and it's handled anything thrown at it. After several years service the nyalic finish is shot, I need to either renew it or let the hull go "natural." Lots of fish have met their ends on its deck...
Chuck
Old 11-25-2011, 01:44 AM
daiquiri's Avatar
daiquiri daiquiri is offline
Engineering and Design
Rep: 2574 Posts: 2,731
Skypoke, was the broaching issue resolved?
Old 11-25-2011, 06:00 AM
cyclops2 cyclops2 is offline
Rep: 94 Posts: 234
What happened skypoke ?
Unofficial N A solution.
Put in a VERY DEEP keel. Full length . Stop the keel far enough foward of the engine in the STANDARD location. There is NO SENSE to putting in a keel that causes a loss of control when in broaching seas. Nothing accomplished.
Keeping the engine in the original location should pay for the cost of the full length.
Lets see.
No keel in the bow causes the bow to be pushed around by waves easily.
No keel in the stern causes the stern to be pushed around by waves easily.
What modification will correct both dangerous conditions with very little steering effort ?
Rich
Old 11-25-2011, 06:06 AM
Rep: 670 Posts: 2,457
Well...best to slow down or bring the bow up. I cant see any benefit to addition skegs. The added lateral resistance just causes tripping.
Old 11-25-2011, 06:50 AM
Rep: 94 Posts: 234
O K
We should have not gone out or came in sooner.
Rich
Old 11-25-2011, 08:41 AM
And as far as the bow biting into the back of a wave , slowing the boat down causing the stern to catch the bow. This happens to all craft. An alert throttle man is required to work the wave trains.
Tendency to broach during beat or close reach Joakim Sailboats 18 10-30-2008 01:21 PM
Bob Sherbert Correction Kay SS Boatbuilding 8 08-13-2007 08:59 PM
Self-ignition tendency of some oils MikeJohns Materials 6 05-30-2007 04:14 AM
Savitsky correction for waterjets? nemo Boat Design 10 05-02-2005 08:00 PM
Broaching in powerboats Murray Hallam Powerboats 12 05-07-2004 11:10 AM
