Old 06-08-2005, 12:01 PM
rona rona is offline
Rep: 10 Posts: 9
Brass CZ112? fasteners?
Using a naval brass CZ112 with satin chrome finish and also Bronze powder coating..I am confused and do not want any corrosion of the metal so my questions are:
1. which fasteners should I use? is Black steel is acceptable
2. How resistant is the Naval Brass? or will it be better to use the High tensile Brass CZ114?
I will appreciate your help
Old 06-08-2005, 03:39 PM
D'ARTOIS D'ARTOIS is offline
Rep: 311 Posts: 1,069
Brass Fasteners
Rona,
First of all, you should be more specific about the materials c.q. environment you will use those brass fasteners. That info is most crucial for a succesful application.
And, what is a fastener: a rivet, a blind rivet, a bolt or a spike/nail?
Old 06-09-2005, 04:21 AM
Rep: 10 Posts: 9
Hi there,
It's an architectural lighting fitting for a yacht.
I will prob.ly use screws. In the meanwhile I thought I might use Nylon 6 screws (also good to absorb the vibration from the engine)
What would you suggest?
Old 06-09-2005, 05:34 PM
Fasteners
That is what I wanted to make out: is that part vibration free? Nylon is not such a bad choice, but it hardenes out and will break after some years. You can use it if replacement is easy, lampfittings suffer always a bit from leaking current and therefore the area around the fitting might corrode. Therfore avoid the use of brass unless you screw in wood.
Old 06-10-2005, 07:26 AM
Rep: 10 Posts: 9
Many thanks for your help, but I have another question coming up: I am using Naval Brass CZ112 and I am facing the question whether to silver solder or bronze braising it.???
Old 06-10-2005, 08:01 AM
That depends on your ability - I would choose for bronze braising instead of silver soldering for the simple reason that the joints of the bronze-braizing are easier to treat afterwards and to finish than the silver soldered joints, where you will have difficulties with the after treatment.
I understand that you manufacture these kind of lampfittings - units and therefore your questions. Mounted on to fiberglass or wood, you can easily use bronze screws; mounting on to aluminium or steel surfaces, use a non corrosive screw, if the screwhead is visible, make some small caps to cover them up, in case you use nylon screws.
Vinex produces coated screws which have a good corrosion resistance and are available in som colours.
Good Luck!
Old 06-10-2005, 08:06 AM
Rep: 10 Posts: 9
Many thanks for you help! I think I might use Nylon 66 as for screws specialy because of the vibration and also because it is not that easy to find the right size in brass or silicon bronze screws in the UK.
I will look at Vinex website. again, lots of thanks and all the best
Nickel plated Brass screws rona Boat Design 1 07-25-2005 06:47 PM
Nickle plated brass rona Boat Design 0 07-22-2005 09:28 AM
Fasteners in strip planking jfblouin Wooden Boat Building and Restoration 5 03-04-2005 07:14 PM
Fasteners Materials 1 01-24-2003 07:37 PM
Fasteners Boatbuilding 3 10-16-2002 03:23 PM
