Old 05-14-2006, 06:10 PM
Hisham Hisham is offline
Marine engineer
Rep: 28 Posts: 45
Box shape Barge resistance
for any type of ship total resistance = 1/2 ( density * v * A * Ct)
Ct -----> Total resistance coefficient (including wave making resistance)
the common known methods for predicting Ct can't be used for box shape barge
Ct for box shape Barges should be constant since the shape is constant
can any one give me a range for this coefficient?
or where can i fiend a good document about this?
Old 05-15-2006, 10:10 AM
Rep: 1623 Posts: 1,483
Ct is not constant for a box barge. It is a function of B and T. It can also vary by -50% depending on bilge radius. And rake adds a whole different issue.
Old 05-15-2006, 06:38 PM
SamSam SamSam is offline
Rep: 464 Posts: 1,608
Are you talking about the chine radius? If I built a scow type hull, rounded chines would have less resistance than a 90 degree angle chine? Sam
Old 05-16-2006, 10:49 AM
Yes, the radius needs to be ~ 10% or more of B to get the maximum restiance per ton reduction (after about that tonnage starts going down faster than the resistance). Noticable improvenents are seen with the radius as little as 2% of B. See Hoerner: "Fluid Dynamic Drag".
Old 05-16-2006, 07:37 PM
Marine engineer
Rep: 28 Posts: 45
haaaaaaaaaaaaaaay
i was asking.. how i can calculate resistance for box shape barge
need help plz
Old 05-17-2006, 12:37 PM
Come on, Hisham, this is easy. A second year hydrodynamics question...Just figure out the pressure drag and add the surface drag. Get your pressure coefficients from Hoerner or Blevins.
Old 05-17-2006, 03:20 PM
Guillermo's Avatar
Ingeniero Naval
Rep: 2041 Posts: 3,567
Some info at:
http://boatdesign.net/forums/showthread.php?p=12081
A computer program:
http://www.ds-t.com/software-cd/soft...0TechSheet.pdf
http://www.hydrocompinc.com/knowledg...ngPowerITB.pdf
Also a simple downloadable Propulsion Prediction Program, based in Holthrop. See if your barge is within the range of applicability.
http://www-personal.engin.umich.edu/...b/newpage1.htm
Cheers.
Guillermo Gefaell
Moon Yacht Design
Old 05-17-2006, 08:23 PM
Marine engineer
Rep: 28 Posts: 45
tahnks...... i am going to check them
alternative to stuffing box? need-help Boat Design 2 03-23-2006 10:34 AM
CD box blown? revshot Outboards 9 02-24-2006 04:40 PM
Resistance of barge satyamoec Open Discussion: All Things Boats & Boating 2 07-21-2005 02:07 AM
Engine gear box Guest DIY Marinizing 11 10-23-2004 07:34 PM
Ice Box Rebuild Lew Morris Sailboats 15 07-11-2004 08:14 PM
