Old 05-07-2007, 04:44 PM
lewisboats's Avatar
Obsessed Member
Rep: 1517 Posts: 2,007
Bolgeresque Noodle
Playin' with this very Bolger-esque type cruisin' shallow water boat hull design. It has a box keel and 7 ft headroom in the cabin along the 3 ft wide (center) box keel centerline. It is 30 ft long with an 8 ft beam and it should be trailerable. Lookin at 1/2" and 3/4" ply for construction, it drafts 33" @ 7 (long) tons total displacement (salt). I was thinkin of a Gaff Ketch rig of about 350 sq ft with a very forward fo'mast...similar to a Cat Ketch. This is to keep the cabin open. I was wondering if there are any thoughts on the thing...constructive critique so to speak
Old 05-07-2007, 05:27 PM
alan white's Avatar
Rep: 1335 Posts: 3,537
Practical design. The hull is narrow but initially very stable, at the cost of quite a bit of submerged area. The headroom is such a plus, and it's obvious the sailpaln is small for the displacement, but as far as comfort and space go, along with beachability and trailerability, what could give you more?
Great canal boat (Erie canal for example) and a nice livaboard coaster/riverboat.
I don't know about the abrupt cutaway forefoot. Angle it and ride over what you might otherwise smash into.
alan
Old 05-07-2007, 06:03 PM
timgoz's Avatar
timgoz timgoz is offline
Rep: 277 Posts: 1,069
Even at this early stage she has a certain charm. The headroom would be attractive to me as I am of the taller variety. Will you incorperate a centerboard, or does the keel provide the needed lateral resistance for decent upwind work?
TGoz
Old 05-07-2007, 07:58 PM
lewisboats's Avatar
Obsessed Member
early estimates would indicate that he keel is sufficient for reasonable upwind work. It is a cruising design...nothing like a dedicated racer but plenty of room for an iron breeze. Even with 6" of extra sole height there should be decent headroom for most in the cabin. I most like the developability of the hull for Plywood planking....a quick and easy build. The hull is a simple 20 panel and chine log knock together with ply butt blocks for the joints and glue and screw construction... if the ends justify the means. My biggest worry is getting enough weight to get it to float on its lines...it needs a very heavy Lead shoe (2-3 long tonnes) to get it to its lines...or lots of internal cargo and ballast.
Steve
Old 05-07-2007, 08:04 PM
timgoz's Avatar
Steve,
Once you get her finalized let me know. I may be interested in obtaining plans. Thanks.
TGoz
Old 05-07-2007, 08:26 PM
lewisboats's Avatar
Obsessed Member
Originally Posted by rayk View Post
lewisboats,
Charming indeed.
But with such a large box keel, a lot of displacement is down low. Would need a high ballast ratio...
Could the box keel be narrowed a little, the bits you shave off added to the hull, and still be compatible with your concept?
A deeper hull would create more headroom without raising the deck or sheer too.
Thanks...
Believe it or not...I actually reduced the width of the keel by 2 ft before posting. I would expect 2+ tons of ballast to be a high ballast ratio on a Plywood boat of this length/width/height. The deeper hull would require MORE ballast to prevent an over abundance of windage...just to sink it to its lines plus there is more draft ... The hull is wider than the keel and displaces more... requiring more ballast. The idea of this is an easy build with a roomy interior and reasonable...not exceptional perforance.
Steve
Old 05-07-2007, 08:34 PM
lewisboats's Avatar
Obsessed Member
Originally Posted by timgoz View Post
Steve,
TGoz
Wow...I've never had anyone asking about plans this early in the concept...Anything in particular you are looking for?
Steve
PS: I haven't been paid for a plan yet...so I ain't advertizin'
Old 05-07-2007, 09:11 PM
timgoz's Avatar
Headroom, simplicity of build (KISS), seaworthiness. I would prefer a small inboard diesel for aux. propulsion & a low aspect relatively simple sailplan.
I look to live aboard most of the year, most likely in coastal North Carolina, though I'm somewhat of a wanderer and she would not be a permanent marina dweller.
Hopefully you can keep us updated as things progress.
Take care.
TGoz
Old 05-07-2007, 09:26 PM
lewisboats's Avatar
Obsessed Member
Due to overwhelming demand on this and other forums...an update with the Keel extended to the bows and angled at the aft. Displacement increased by.3 tons...or 675 lbs.
Steve
This is my opinion...only my opinion and subject to the fact that I may be full of S!!t...or Rum... or beer...among other things...
Lewis Boat Works
http://angelfire.com/ego/lewisboatworks
Old 05-07-2007, 09:32 PM
alan white's Avatar
One thing that strikes me is the structural challenge of hanging that keel. Normally, the floors are present, but here there is a need to walk above the ballast, so I assume the keel box sides are carrying from two very healthy bulkheads. The box keel sides then become longitudinal beams.
Also, being so low, is there some drag to the keel, enough to allow maybe a 6" deep sump area?
I love boats like this. I would even make my own mild steel fittings and have them hot-dipped.
Here's two scenarios: Owner #1 builds a rough and ready boat out of common inexpensive materials, and does so for 20k. The other owner worries about the resale value of a plywood boat built that way, so he spends 50k and "does it right". Later after 30 years of hard use, each boat is sold. The cheaper boat sells for 5k and the more expensive one for 25k.
The way I see it, the cost-saver boat owner lost 20k and the other guy 25k, and all along the way, the cheaper boat was a lot more fun to own, insured for half, and cost half as much to maintain... for 30 years.
Alan
Old 05-07-2007, 09:40 PM
lewisboats's Avatar
Obsessed Member
I like those numbers...the frugal yachtsman of the 21 century...
Steve
Old 05-07-2007, 10:32 PM
lewisboats's Avatar
Obsessed Member
Take care.
TGoz
Funny...I have been considering moving to S Carolina after I shed the payments to the ex. and finally have some money for myself. How handy are you? I could come up with the the basic offsets in no time but the interior and outfitting would take much consideration and probably wouldn't suit you anyways. Look at what you would have to work with and what you would need...come up with what would suit you and see if it would fit into the allotted space. figure out where the major weights would end up and let me know. I can work around and adjust things +or - to level the basic design.
BTW I am no pro and don't claim anything other than journeyman knowledge. I have 8 different builds of my own designs under my belt...7 of which have been successful and a couple of other which have been built by others which have also been successful.
Steve
Steve
Old 05-07-2007, 10:44 PM
timgoz's Avatar
I'm pretty handy & require spartan accomadations. We'll keep in touch. My email is tvmdcaw@zoominternet.net.
I love Carolina. Good people down there. The heat will take getting used to though. I to am kept here by family obligations at this time.
She could probably be driven with a 10 hp inboard wouldn't you think?
Gotta get to bed now, as I have an early morning.
Take care.
TGoz
Old 05-07-2007, 11:12 PM
lewisboats's Avatar
Obsessed Member
I have your email...look to it for further converse.
Steve
Old 05-08-2007, 11:53 AM
timgoz's Avatar
Thanks Steve.
Bolgeresque Noodle lewisboats Boat Design 0 05-07-2007 04:44 PM
