Old 09-05-2010, 12:13 PM
peterchech peterchech is offline
Rep: 127 Posts: 220
Bolger Cartopper finally completed
So only one pic with the sailing rig set up because I'm still refining the rig a bit to help sail closer to the wind and prob will add a jib to help tack into the wind. I also am going to get rid of the flotation compartments, and maybe tie in some alternate flotation (floating seat cushions I'm thinking) because the weight of the build was too much to easily cartop. I'm going to also get rid of the wrap around seating, because the boat is too tender and the seats aren't being used. (just adding weight). I made the sail from a regular canvas painters tarp, and it stratches a bit so the pocket I sewed into the sail is now too deep, gonna prob redo the sail but stick with the gaff rig because it's so beautiful and here on the jersey shore there is a long tradition of "sea bright skiffs" using a low masted gaff rig with a jib (why break with tradition?) The build took 3 months of spare time, I used AC exterior 1/4 in ply for planking, covered in 10 oz fiberglass on the outside and painted on the inside. Mast is hollow birdsmouth, 10ft tall. Spars are clear douglass fir.
Old 09-05-2010, 12:17 PM
Submarine Tom's Avatar
Mariner
Rep: 937 Posts: 1,941
NICE JOB.
-Tom
Old 09-05-2010, 10:57 PM
troy2000's Avatar
troy2000 troy2000 is offline
Rep: 1686 Posts: 1,240
Always glad to see new homebuilt boats on the water; thanks for the pictures.
Have you noticed any problems with that high bow catching the wind and shoving you off track, when you're rowing?
"All one has to do is follow the plans and build in no permanent leaks."
-Charles Minor Blackford, on the simplicity of building flat bottomed boats
Old 09-06-2010, 09:48 AM
Rep: 127 Posts: 220
It hasn't been an issue at all when rowing, believe it or not. Between the skeg and the wood runners i put on the bottom of the hull once u get her moving she tracks straight in just about any wind. But yes, as soon as u stop rowing for a few seconds, for example to raise the sail, the wind spins this boat in circles and makes things difficult...
Old 09-06-2010, 10:13 AM
Easy Rider's Avatar
Easy Rider Easy Rider is offline
Rep: 694 Posts: 670
Another similar design of his that I like a lot is his Thomaston Galley. The TG dosn't look at all like your boat peterchech but designed for and is clearly good at the same things. The TG has a big wide fat stern and a bow that hardly exists. Very low freeboard.From a distance you'd think she was a flat bottomed pram but in fact she has a very deep V hull.
Easy Rider
24 Hp Mudmotor Finally Finished muddin redneck DIY Marinizing 24 06-05-2010 10:03 PM
New Nester Completed lewisboats Wooden Boat Building and Restoration 1 03-25-2010 02:51 PM
Online Store is Finally UP and Running gcmdistributor Boat Design 0 02-03-2009 09:05 AM
I finally made it home! Distans 52 Open Discussion: All Things Boats & Boating 21 01-08-2009 07:58 PM
5.4 meter Assult Boat plan for sale...completed set...just for USD 500 fadly2000 Services & Employment 0 07-02-2001 12:40 AM
