| Boatbuilding roadbumps Im building a slightly tweaked version of Bolger's Windsprint and have so far all the necessary plywood parts cut out. Some questions... I have a bunch of fiberglass cloth in 3x3 foot sheets, can I just cut these into strips to substitute fiberglass tape and cover them in fiberglass resin? For butting the plywood, will fiberglass cloth and resin work? I plan on covering the bottom of the hull with fiberglass cloth and fiberglass resin, and then sanding, what kind of paint should I use? For the inside of the boat, can I just apply a coat of fiberglass resin on top of sanded plywood without the cloth underneath? Should I use fiberglass resin or marine wood glue when attaching the gunwales to the side with clamps? What is the difference between fiberglass resin and epoxy? Sorry so many questions but I have a lot of building time tomorrow and would hate to waste it. Edit: I just had a idea I thought I would through out there... In theory, could I build a plastic glass type window on the hull so I could see underwater?
__________________ "Not all those who wander are not lost" -Tolkien Last edited by SPI-sail : 06-19-2008 at 01:10 AM. Reason: adding new idea |
| I can give you some of my meanings, others will pop up.... First; you can use (at least, to my knowlegde) Vinylester resin + glass, polyester resin + glass, epoxy resin + glass. For stronger things replace glass with carbon, boron, kevlar, whatever, but not all types of mat mixes well with all types of resin, as some are pretreated with something, beyond my knowledge. Fiberglass cloth you have is probably multiaxial, and i would have noe problem by stripping it up like that, but for stressed areas, I would buy woven cloth, a bit stronger. for butting; normally now people tend to go for epoxy, the main reason is that epoxy normally bonds better to wood surfaces, also is it more waterproof. As a general rule, I've learnt: you can use epoxy on top of polyester, not the other way. You will have to get the surface rubbed up, and degreased, to make it stick. Epoxy is pretty waterproof, vinylester is less waterproof, and polyester is not waterproof, kepp that in mind, as Plywood can take in water, expand and make the surface crack, increasing the speed of the problem.. "Last" coat; I would go for some epoxy, to seal the surface, that will be both the inside bottom, and the outside bottom, or the complete outside. Window, you dont build a window, you buy it... A plexiglass piece (or whatever) And yes; If faired into level with the bottom,, preferably rounded edges, frame made water tight, window glued in with some Sikaflex (Polurethane(?) flexible rubberlike glue. Kids will love it. Keep it away from grounding or walking area or areas with curvature of the boat... Do not take away the protective plastic on other parts than where you will have the glue during construction... Good luck. Btw; there are pleeenty information here if you lurk around..:-)
__________________ KnutS "it's dark and we're wearing sunglasses" |
-if the cloth you have is woven cloth, it will work, but it will become very loose, so handle with care. -if the cloth you have is CSM (random orientated fibers) then it can only be used with polyester. More on polyester later. -if the cloth is multiaxial (orientated fibers, laying on top of each other, held togehter with stitching) then you are OK. If possible, have the fibers orientated in +/-45 direction. Makes for a stronger bond. Quote:
If you are referring to polyester resin, please do not be tempted to use that without fibers. Quote:
Polyester resin and wood are not the best option. Adhesion is poor, and the resin is not so versatile as epoxy resin. (which can be used for laminating, glueing, coating and sometimes even casting (potting screws in oversize holes)). Polyester resin basicly is just for laminating. Quote:
However, first get yourself some confidence that the other structures of the boat are safe and sound, and that you can tackle the project. It is quite easy to build in afterwards, so it is not that big of a concern.
| Plywood butt joints can be done and quite effectively, but you have to use epoxy and employ the "save a butt" method, which uses cloth on both sides of the joint. If the joint line is "plowed" out a bit with a grinder before the fabric is applied, it can be hump free when completed. Making an underwater port is a difficult thing. You must remember there's a lot of pressure involved and any joints, seams and seals will be tested. The successful versions of these ports have pretty highly engineered seals and gaskets. |
| What epoxy to use? Where should I order from online and what brand and hardener should I get? I need something that doesnt require fiberglass cloth but will use that for the outside of hull. So far I both sides cut out, frame molds, and wood for the chine longs, but need the epoxy to butt the sides
__________________ "Not all those who wander are not lost" -Tolkien |
| Epoxy alone will not offer much more then a sealer coating on the exterior of the hull. Abrasion resistance comes from a fabric sheathing set in epoxy. All the major brands of epoxy have very similar physical properties. Though you can mix different brands of hardener, it's generally not recommended for the novice user, use the same brand and correct ratio hardener for your resin. Hardener type (speed) is temperature sensitive, depending on your building environment. Most permit on line shopping for their products. Do some reading, possibly at one of the epoxy manufacture sites. Most have a fair amount of "how to" information, which will be valuable in you first attempts. There is also quite a bit of information here about epoxy and it's use, so the search tool will be handy. |
| And try and get a brand that is (more or less) readily available in your area. West System has some nice documentation, it is worth getting that to you (they also have a lot of info online). The info they give is basicly also applicable for other epoxy systems. The only thing that could be different is the mixing ratio. Always stick to the mixing ratio given by the manufacturer.
| New to Boatbuilding... Need Help | Viper2 | Multihulls | 9 | 02-26-2007 04:35 PM |
| bondo boatbuilding | tugboat | Fiberglass and Composite Boat Building | 5 | 10-06-2006 08:15 PM |
| New Boatbuilding Company | 25or6to4 | Services & Employment | 1 | 07-25-2005 03:42 PM |
| Future in boatbuilding | flajjer | Open Discussion: All Things Boats & Boating | 30 | 06-05-2005 01:16 PM |
| Boatbuilding books | Dutch Peter | Open Discussion: All Things Boats & Boating | 0 | 12-19-2004 01:47 PM |
