| Boat yard utility " painters float " I was getting ready to construct a simple stitck and glue plywood, 16 x 6 ,decked over, double ended punt for use as a general work float, painters barge and got to thinking.... What If someone jumps on my float, falls in the water and takes fright, I might get SUED for having this utility float that is not certified...ie stability curve, construction scantlings. I surfed thru the internet looking for stock designs and no luck. I'm not interested in a couple 55 gallon barrels strapped under a deck. The floats Ive used in the past are proper boats. Double ended, decked over punts along the lines of a push-me, pull-me ferry . A Scow... with Big chunky stand off rub rails , right down low at the waterline , so the float rides clear of a yachts topsides, a keel and skeg for directional stability, self propelled with a little 2 horse outboard in a well stuck thru the middle of the float deck. Any suggestions ? Such a simple boat, feel a little silly going to a naval architect. Any stock, calculated plans on the internet. ?? |
| How about the 'Fish Cat' by Phil Bolger? - 16' x 7 ' , two hulls (catamaran) can run an outboard. Probably easier to pack up as the hulls can be separated. Lots of stability to stand on and paint etc There are probably a few Bolger designs that would suit - simplicity being the key. |
| A cat might do the trick. At 7 ft beam she is starting to get a bit beamy, might be tough to squeeze her between yachts and get to work. The ultimate work float would be a long , very narrow, MAGIC FLOATING PLANK ! Also its good to have plenty of buoyancy in the ends, your frequently nosing into a blind alley to get at some repair. Perhaps a cat could do it, Phil Bolger might be a good man to contact, he has plenty of boatyard time . Sam Devlin , with his sleds, would be worth an email |
| Here we use styrofoam under a simple frame with any decking material, for a float. Think floating dock , not boat. Its towed with a dink from boat to boat . Even a burorat can tell a float from a boat. Soft rub rail on all sides makes it useful alongside. Unless the boats are huge , only a few inches of freeboard of the raft allows working down to the WL. FF |
| CMD "project Zeus" VS VOLVO "IPS" | gerard baladi | Pod Drives | 13 | 09-10-2007 09:23 PM |
| Boat "workshop" including a "testing tank" | zmfmd | Open Discussion: All Things Boats & Boating | 0 | 08-08-2007 04:43 AM |
| Westlawn ? "Lite" versus "Module 1" | MikeT | Education | 2 | 10-10-2006 12:13 PM |
| "Float your boat" school cardboard boat project | katermalin | Boat Design | 5 | 04-18-2006 09:34 AM |
| Drawing for Rhino of "Boat Racing Chair" and "Machine Gun" | Vibtor | Software | 0 | 10-02-2004 02:03 PM |
