Old 01-22-2006, 12:15 AM
Rep: 3125 Posts: 9,397
The true issue isn't if a wooden trailer could be engineered, it certainly can (think paralam) but the point is, can it be registered, which appears not too likely, making it a moot, if not quant, point.
Old 01-22-2006, 08:26 AM
lewisboats's Avatar
Obsessed Member
Rep: 1263 Posts: 1,840
Depends on where you are in the country. I could walk into the local DMV and get a "home built utility trailer" licence that has a capacity of under 2000 lbs or 2 tons (I forget which) for $10, no inspection or anything.
Steve
Old 01-22-2006, 08:29 PM
Steve, the original post is from above the boarder, in Quebec, which doesn't permit wooden boat trailers. I find it had to believe they (Iowa) wouldn't require a registration number be affixed to a home built anything that was going over the road, regardless of capacity. If it carries a tag . . . Maybe in Iowa this is true, but major metropolitan areas will nix the idea in a heartbeat, particularly if it was rated for carrying over a ton.
You verbosity has gotten you senior status. Time to give up caffeine?
Old 01-23-2006, 08:20 AM
john olsson john olsson is offline
Rep: 10 Posts: 4
it would float!? he he :-)
If it were to be called composite instead of wood, it could be street legal.
Old 01-23-2006, 08:47 AM
lewisboats's Avatar
Obsessed Member
Like I said, I talk too much.
Steve
Supporting a Boat off-trailer for work? djkingmatt Fiberglass and Composite Boat Building 4 05-16-2005 02:43 PM
Wiring up a boat trailer Fred Voorhees Electrical Systems 1 02-27-2005 10:29 PM
Designing a trailer sail boat Bioptica Sailboats 10 11-23-2004 04:05 PM
8000 lb BOAT TRAILER FOR SALE sharkeymarine Marketplace 3 04-28-2002 12:07 AM
Boat trailer plan for SALE just for USD 200 fadly2000 Services & Employment 0 07-02-2001 12:38 AM
