| Boat Plans ? hey ... i'm thinking about building a small (20 to 25foot) sailboat, -low budget, plywood radius chine, fast cruising, trailerable, Does anyone have or know where to get free or cheap plans?? thanx roland |
| The cost of a good set of plans is 1/3 to 1/2 the cost of a jib, and good plans are cheaper to build to than cheap plans. The only "radius chine" boats I know are from Dudley Dix (http://www.dixdesign.com/). If you want the other things (low budget, plywood, fast cruising, trailerable), I would suggest Jacques Mertens Vagabond 23 (http://www.boatplans-online.com/prod....php?prod=VG23). Jacques would call it a "plywood core, fiberglass boat" because the glass sheathing (inside and out) is a critical part of the construction. There are cost estimates on the study plan portion of the website. |
| Thanx ... i know the dixdesign boats ... they're great, and i thought about it allready. but the mini didi is more a racing boat then a cuising boat and she has a fix keel. i need a boat with drop keel. and the didi26 is just a bit too big for my first building project... What do you think of this natali600 ? http://www.yakutia.ru/~igor/natali600/ |
| Why radius chine? Is radius chine important to you? and why? You'll find that there are more multi-chine and hard chine plans out there than radius chine ones. They're typically easier to build, especially as a first project. And the primary advantage of radius chine is aesthetic. Bruce Roberts's Spray 22 is a good-sailing boat, easy enough for an initial project, and a thoroughly proven design. (Just one of many possibilities.) Luck. |
| why radius chine? because of the design and the resale value.. i wanna build a modern fast cruising boat .. and i dont think it is much more difficult to build, think it just needs a bit more time.... |
| High-Speed Waveless Boat | waveless | Boat Design | 82 | 10-10-2005 08:01 AM |
| jet boat plans | scotty b | Powerboats | 6 | 04-20-2005 04:19 PM |
| Looking For Small Fishing Boat Plans Alum. | PDH | Boat Design | 3 | 03-21-2005 08:56 PM |
| Need boat plans (please help) | EMporto | Boat Design | 1 | 11-22-2004 07:25 PM |
| Original Boat Plans for Sale | eric dahlkamp | Boat Design | 0 | 08-06-2004 10:00 PM |
