Old 09-11-2007, 08:22 AM
Jenhvy Jenhvy is offline
Rep: 10 Posts: 3
Hello,your ship is just like a variant of yachts, but that's a good idea, I would like to ask you, what software do you use to design the ship? 3D or any other software? ?And inorder to make your boat to be an ice-breaking one, I think the bow should be made a little sharper and the stern platform shoulde be raised, or it will be submerged under the water.
Old 09-11-2007, 10:16 AM
Sudarikov Sudarikov is offline
Rep: 10 Posts: 36
Thanks for advices I ll do my best.
I used 3d max, it is good way to make fast draft models. Before it i made many scetches.
Old 09-11-2007, 10:30 AM
kach22i's Avatar
kach22i kach22i is offline
Architect
Rep: 1067 Posts: 2,299
Originally Posted by Sudarikov View Post
1) Special conditions:
Could move in the crushed ice
2) Engines in board
Desiel dose. Propeller
3) Hull: flat bottom, or shallow v shape, or catamaran. Quite square. Its going to be good in rivers and OK at sea.
4) Opening parts
.............Back part of boat has pod for raft. The front will open to let people go in and out anywhere
5) Range, how far will it need to go
500 miles with about 1000 gallons
6) Storage for food
For a week
1. Do you mean "ON" or "OVER" or "THROUGH"?
2. That's a shallow draft, surface prop near ice? I'm no expert, but that might be a problem. Perhaps some type of protective duct should be considered.
3. Sounds like a good shallow river hull. Rough seas may require you to ballast the craft down for stability, this may help keep you upright, then again I'm not expert.
4. If breaking ice an operable the bow becomes a problem as it will take a lot of abuse and forces. Just about anything can be solved by shoveling money and time at a problem, good luck.................The stern detachable? I guess that rules out surface props, which indicates a deeper draft and requires deeper water in which you can operate.
5. Range is a good question/topic. I also think that having extra food provisions and spare or extra fuel is a must should you ever get stuck in the ice. Just something to consider.
EDIT:
Have you seen this hull yet?
Help Identifying military 36 foot inverted V hull
George: Architect (land lover type)
Hovercraft & Vintage Porsche Owner
http://www.boatdesign.net/forums/boa...ect-11973.html
Old 09-11-2007, 03:48 PM
Guillermo's Avatar
Ingeniero Naval
Rep: 2069 Posts: 3,574
Sudarikov,
I think I would like to know first your estimatives on lightship and loaded conditions, stability, transverse accelerations, intended propulsors, behaviour in waves under speed, etc., before going any further.
Budem zdorovy!
Old 09-24-2007, 02:44 PM
Rep: 10 Posts: 36
Budem zdorovi!!!
So, I made it! My diploma work is finished. Let me introduce my boat to you, my dear friends.... I want to say thank you for all for advises even if I did not show them on my board, it is of time insufficient.
I understand, that project is not complete but it was a task for design and stylish for 3 months.
If you are interested in my design or presentation I would be very glad to discuss them
Thank you all!!!!
Cavitation ( under certain conditions ) Rett Propulsion 2 12-14-2005 01:18 PM
Schedule of conditions for a new project trimix Boat Design 5 04-16-2005 04:04 PM
Float design under laminar conditions Nidhi Boat Design 5 10-05-2004 12:35 AM
The Too-hard Basket tom kane Powerboats 11 12-19-2003 07:20 PM
Hard chine boat design Guest Boat Design 0 09-10-2003 10:50 AM
