Old 01-29-2004, 06:05 AM
andy123
blade thickness
Hi,
Need help with the following link.
http://mission.base.com/pedal-power/pp_prop1.html
Drawing this propeller in 3D package. The method i am using is drawing three different sections, one at the hub, one at the max blade width and one at the blade tip and then lofting them. Can anyone interpret how to find the bladewidth at these three points? The paper says the max blade width is 4 inches at a radius of 5 inches. What is the blade width(chord) at the hub and the tip?is it also 4 inches?
Old 01-29-2004, 09:42 AM
duluthboats's Avatar
Senior Dreamer
Rep: 771 Posts: 1,578
The blade dimensions for propellers are displayed as cross sections like a wing. I’m sure there is sound engineering that determines the dimensions for each style prop. The variety is almost infinite. Here is two different styles.
Gary
bigger props faster ship? Peter H Boatbuilding 23 02-01-2010 01:08 PM
Pros and Cons of Transom Hung Rudders Gone Ballistic Sailboats 19 09-19-2005 09:15 PM
Fiberglass thickness rturbett Fiberglass and Composite Boat Building 3 09-09-2005 08:36 AM
plating thickness? rlackey Boat Design 31 07-17-2005 06:18 PM
FRP hull thickness tdamico Boat Design 19 09-14-2004 09:20 AM
