Old 12-09-2007, 05:54 PM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 2057 Posts: 4,291
Big steering wheels
Why do boats have such large steering wheels ?
Is it so one can make small corrections or do one use a lot of force to steer or both ?
Can one use a push-pull steering mechanism on small yachts that steer the rudder ? I see most guys have a piece of pipe they steer with.
Regards
Fanie
Water ! Just gimme water !
Old 12-09-2007, 06:07 PM
masalai masalai is offline
masalai
Rep: 1689 Posts: 7,507
Ahhh Fanie, I would love to stir (not you so I won't) If there is loading then the design is poor I reckon it is just to hold on to something.
The extensions are to enable steering whilst leaning out using a trapeze and some of the older vessels such as square riggers, had about 12 turns lock to lock to use automobile jargon.
Old 12-09-2007, 08:38 PM
Previous Member
Rep: 0 Posts: 0
Some of the bigger boats have two wheels. It is not so two people can steer at once. Same reason as a large wheel, it allows the helmsman to site the sails and what is approaching as well as contributing to ballast on the windward side or lee side in light air.
Rick W.
Old 12-09-2007, 11:34 PM
Loveofsea Loveofsea is offline
Rep: -68 Posts: 148
Think minimal...
http://digital-lifestyles.info/2006/...-boat-control/
Old 12-09-2007, 11:53 PM
masalai
You do not need to go volvo, Joystick has been around for ages. A 20m alloy cat that was used in the passenger run to Magnetic Island _ off Townsville, Queensland, Australia used a joystick for control of 2 x 450 hp cummins and steering. It cruised at about 24 knots with 110 to 150 passengers (different configurations as it initially went into service in the 80's for Hayman Island I think. It sold recently for less than Au $440,000. Would make an excellent live aboard!
Old 12-10-2007, 01:30 AM
Fanie's Avatar
Fanie
I can imagine the tug of war if it's a man and (hard-headed) wife eh !
I have made my motorboat joystick control some time ago, but converted it back to the steering. It may have it's place but was a bit sensitive on a planing powerboat. A progressive control would have given better results though.
Regards
Fanie
Old 12-10-2007, 06:49 AM
yipster's Avatar
yipster yipster is offline
Rep: 1083 Posts: 3,337
on tv i saw the incat ferry steering wheel in a armrest big as your thumb
Old 12-10-2007, 09:30 AM
tuks tuks is offline
Rep: 35 Posts: 78
http://en.lewmar.com/products/index....g=1&page_id=33
Here are some steering systems, if you want to go with a spade rudder and a wheel.
A transom hung rudder with a tiller is simple and easily removable, which is important for a trailerable boat. In a 10m monohull, I would go for a tiller, but im not sure what the steering loads on cats are like. If you go for a transom hung rudder dont underestimate the loads, they are bigger than you might expect.
Old 12-10-2007, 02:05 PM
masalai
The original one was on the "bench" forad of the pilots throne. I saw another one with a dicky little wheel, as fancy as all getout just like the sailing ships of olde but pinched from a model and only 2 inches in diameter. As my lady of the time said "It's soooo cute!"
I think the sunferries one afectionately called "the bucket" was about hull#6 from incat.
Old 12-10-2007, 04:52 PM
Fanie's Avatar
Fanie
I may get a small round wooden table and screw some wooden draw knobs around the edge
This is cool, if there are no specific reason for having to use a BIG steering wheel (could have doubled for anchor) then I may look into making a rack and pinnion type steering mechanism.
Regards
Fanie
Old 12-10-2007, 05:01 PM
masalai
Hay Fanie, you are a multihull sailor! Keep the weight down and adhere to KISS (Keep It Simple Stupid). Oh, and go on a diet, 200kg body mass is tooooo big, where is the reserve buoyancy for that white pointer shark or black marlin?
A tiller with extensions, and some lashing so that it can be tied off quickly while you haul in that fish/mermaid?
Old 12-10-2007, 05:18 PM
Fanie's Avatar
Fanie
I'll see how things turn out once I'm on the water
Regards
Fanie
Proa steering SeaSpark Sailboats 75 05-14-2007 11:44 AM
No power steering san Gas Engines 1 11-29-2006 11:29 PM
Propulsion and Steering gondolaguy Inboards 9 08-01-2006 07:37 AM
Steering Wheel garys Boat Design 9 12-20-2005 01:34 PM
Steering Question Travis Powerboats 3 08-13-2004 05:46 AM
