Old 07-10-2008, 02:29 PM
TuckerJ TuckerJ is offline
Best wood?
Hi all, my first post here and its for my first boat that i have bought at 16 very excited. It's a '62 Lone Star El Dorado(So we have come to believe) and I'm redoing everything on it. For the "cabin" walls and floor I want to use wood, but I am not sure what kind of wood to use. I live in central Maine and have plenty of land and a wide variety of trees to use, I just don't know what would be best. I hear Mahogany and White Oak and Cedar are common? So some input on what the best is would be very very helpful.
Thanks, Tucker
Old 07-10-2008, 02:36 PM
Kaa Kaa is offline
Wanderer
Rep: 43 Posts: 34
Go talk to people at
http://www.woodenboat.com/forum/index.php
Kaa
Old 07-10-2008, 08:56 PM
Petros Petros is offline
Rep: 889 Posts: 1,005
Anything and everything has been used in boat construction (even bamboo!). The best woods are anything that is reasonable clear, strait grained, and relatively rot resistant. The woods you list all work well, also common is doug fir and larch, locus, southern pine.
The ones you list are all good with good rot resistance but their weight are at opposite ends of the wood spectrum. The white oak and mahogany are heavy hard woods and will take a lot of abuse, cedar is much lighter with a better strength to weight ratio, and it is easy to work, but it will not tolerate a lot of abrasion or banging around. The woods I listed above are in between these two extremes. I have used all of them.
If none of these qualities are an issue, pick them by appearance since they all have their own unique look (presuming you are going for a 'bright' finish), or by cost. All will serve you well.
Good luck.
Old 07-10-2008, 11:11 PM
alan white's Avatar
Rep: 1211 Posts: 3,325
Thanks, Tucker
Here in Maine, we have little white oak, but we do have white cedar. Clear white cedar for vertical staves can be sawn from between knots (say, 1 1/4" T&G).
Fir also abounds, and vertical grain stock can be quarter-sawn by (for example) at least 2 private one man sawmills here in Eddington.
You need to air dry it, 1" per year.
So I'd say fir and cedar, and maybe white pine would be okay, with cedar at the top of the list.
Alan
Old 07-11-2008, 03:35 AM
Rep: 3125 Posts: 9,397
I'd be inclined to use a wood that wears well, such as pitch pine or other heart pine like species. Cedar is lovely, but quite soft unless it Spanish or you're very selective with heart stock, oak way too heavy, mahogany doesn't wear well, Douglas fur is difficult to get or keep smooth, but wears pretty well
Old 07-11-2008, 08:38 AM
alan white's Avatar
It's true that other woods like spanish cedar or hard pine are well suited to the purpose. Indiginous boat woods (in Maine) are pine, cedar, fir, hackmatack and locust and some others of increasing rarity.
I can get native white cedar in the rough for $1.00 per board foot within five minutes of my house (two different locations).
So of course, it makes sense to build in such woods here in Maine.
A.
Old 07-12-2008, 01:22 AM
diwebb diwebb is offline
Rep: 65 Posts: 120
Hi,
another option is to look at a combination of wood in a panelled format. If you use cedar for the recessed panels and a harder wood for the framing with a hardwood rail located at a height to take most of the hard knocks you may be able to get the best of both worlds from the available wood on your property, or available locally at your nearby sawmills.
wood captain Dan Boat Design 16 04-03-2007 08:40 AM
Looking for right wood jelfiser Boat Design 1 07-28-2006 04:20 PM
Looking for right wood jelfiser Wooden Boat Building and Restoration 0 07-25-2006 09:26 AM
How much wood (would a wood chuck ..)? Square feet/meter DanishBagger Materials 8 02-17-2006 08:32 PM
Anything but wood! MedicineMan Materials 15 05-05-2004 10:34 AM
