Old 09-06-2006, 11:34 PM
mtnrat mtnrat is offline
Rep: 10 Posts: 53
Best way to suspend and turn a boat
I am going to replace the floor and stringers as well as work on the bottom. What is the best way to suspend the hull so it can be turned. It is an 18 foot V hull sterndrive. I have a leanto shed with hugh 12"x18" beams that I can use as well as a garage with 4"x 16" glue lam beams that I can suspend from. What would be good suspension points? What about turning it over so I can more easily work on the bottom?
Thanks
Old 09-07-2006, 06:34 AM
waikikin's Avatar
waikikin waikikin is offline
Rep: 513 Posts: 940
Carefully
Best to roll very carefully, so as not to get hurt.Jeff.
Old 09-07-2006, 07:06 PM
Rep: 10 Posts: 53
:d :d :d :d
Old 09-07-2006, 10:27 PM
Rep: 505 Posts: 1,658
how much does your boat weigh? ,,,do you have a motor in it? how many friend do you have? we turned my 32 sailboat over with 100 people ,,no lead no engine,.,.lots of beer,no bull,longliner .boat weighs 10,000 lbs.
Old 09-08-2006, 09:22 AM
Harry Kosta Harry Kosta is offline
Aussie
Rep: 10 Posts: 9
We turned my 32ft alloy hull with 4 guys .
If you can attach a winch fore and aft, and you can make a bracket that will
suit the sterndrive bolt pattern, then all you have to do is lift and spin.
It might work for you or it might not.
Good luck.
Hazza
Old 09-08-2006, 10:05 AM
bbsboat bbsboat is offline
Rep: -10 Posts: 37
practice,practice!!!!
http://www.theboatpictures.com boat pictures
Old 09-08-2006, 10:35 AM
Rep: 10 Posts: 53
I think the hull weighs 1200lbs. It is an 18 foot runabout. I plan to remove the engine and leg. Just put in a new engine so everything is clean and it will be an easy removal. Here is a pic.
Old 09-08-2006, 12:08 PM
Tim B Tim B is offline
Rep: 763 Posts: 1,384
There are at least two similar threads in which I advocate the use of an A-frame structure. In your case, using webbing straps slung from pulleys on the beam to a winch of some description (ala boat-lifts) would probably be ok if your beams run either side of the boat.
Tim B
Old 09-08-2006, 02:57 PM
Rep: 10 Posts: 53
I can put it in such a way as the beems run either side of the boat. I had not thought of that before. I also have two warn winches that I can rig up. As well as a couple of comealongs.
Old 09-08-2006, 04:00 PM
chandler chandler is offline
Rep: 16 Posts: 378
Chain falls are amazing tools if you have a beam overhead. Cinch up one ease the other etc. etc.
Ways to suspend and turn hull mtnrat Boatbuilding 3 09-15-2006 04:13 PM
Home build? Refurbish? or buy good used turn-key? Wind_Swept Boatbuilding 1 09-20-2005 05:05 AM
1998 Four Winns Lack Of Power During Left Turn KENSINGTONAUTO1 Propulsion 2 07-06-2005 05:10 PM
Hull or hull & deck broke apart during 40-50 mph turn Jeff Powerboats 1 07-09-2002 01:27 AM
