Old 07-22-2007, 04:39 PM
WarrenW WarrenW is offline
Rep: 10 Posts: 12
I ended up removing all of the wood yesterday and now have just the fiberglass sides and bottom. Good thing I did cause the wood was not good on the outside edge either.
I plan to laminate 2 pieces of 3/4" marine play to build the transom and glass it in using multiple layers of fiberglass tape up to 8" wide and then add braces fiberglassed in. That should hold it!
Old 07-22-2007, 07:56 PM
Rep: 501 Posts: 1,767
I would give it a layer of epoxy on top to seal and glue everything. Make sure you clean up all that wood mulch. I used a pressure cleaner and sander
Old 08-13-2007, 12:40 PM
Rep: 10 Posts: 12
Do you think using epoxy all around the bottom and sides to hold in the transome along with fiberglass on the outside and inside corners will hold the transom in there? There are no strings to connect to - only a fiberglass shell hull.
Thanks
Old 07-22-2011, 04:15 PM
rovi rovi is offline
Rep: 10 Posts: 9
What materials should be used to complete the transom,fiberglass matting or woving?
Old 07-22-2011, 06:58 PM
Rep: 3125 Posts: 9,397
The core should be "tabbed" to the hull shell with fabric. 45/45 biax is preferred, with at least 6" on the hull and 6" on the transom. This means you'll need to stagger the seams if using tape. Of course as has been previously mentioned you need a fillet or built up transition from the core to the hull shell so the fabric will lie flat and smooth without air pockets, bubbles, puckers, etc.
Yes, if your tabbing is thick enough (how many layers of what weight and type fabric?) and well bonded to both hull shell and core, it'll hold fine. Your final task is to give everything a coat of epoxy to seal it down.
Replace C/B with Shallow Keel Flumixt Sailboats 18 11-11-2007 10:00 AM
Replace Traveller and Track With What? MMNet SEA Sailboats 20 10-18-2007 02:11 AM
replace a superstructure? Houston.Sail Metal Boat Building 2 05-15-2007 02:15 AM
Replace Transom in my 1982 Sportcraft Deanman74 Fiberglass and Composite Boat Building 0 11-06-2006 09:59 AM
stringers repair or replace? fishweed Fiberglass and Composite Boat Building 10 09-20-2006 11:46 PM
