Old 06-29-2010, 07:56 PM
singleprop singleprop is offline
Rep: 10 Posts: 48
Yes, that is the theory- it works for the airplanes....Not sure if it works in a boat, let the NA's answer that question.
Old 07-07-2010, 05:15 PM
ChrisN67 ChrisN67 is offline
Rep: 47 Posts: 49
Hello Guys,
I got the solution, I am ordering the triple transom ram pickups. THe center pickup will connect to a transom discharge with flapper about 8-12 " about the ram inlet. The ram inlet will plumb to the strainer then a manifold with service to raw water/ genset/ac/toilet. Any overpressure will discharge out the trasom. It just requires one extra hole.
I also purchased an electric 3-way ball valve to protect the genset (just in case) The added benefit is I can "t" into my fresh water system for post operations flushing
Thank you for your inputs
Best thru hull design to keep a gen set running at over 40kntsu Hulls-presentation1.jpg
Old 07-07-2010, 05:21 PM
Rep: 47 Posts: 49
Originally Posted by daiquiri View Post
Good points. Thanks for the correction.
You idea is a good thought, as it is functional for air intakes on the sides of boats where the apparent wind vector is more or less constant even with changes in pitch. I faced this issue when looking for 22000 lpm air intakes. I opted for an air box with custom 48" x 4" CNC intakes
Best thru hull design to keep a gen set running at over 40kntsu Hulls-dsc00308.jpg  Best thru hull design to keep a gen set running at over 40kntsu Hulls-vents2-002.jpg
Old 07-07-2010, 10:12 PM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1693 Posts: 5,849
can I just explain my experience.
I had an overheat prob on one engine 22Kts. everything was checked over on the new engines but nothing found. I hauled the boat and with a 4inch grinder shamfered the leading edge of the bronze through hull fittings lowering the leading edge by1/8 of an inch..
Not a prob since.
New Shallow Running Tunnel Hull Boat Build. Need Help PLZ DOPatrick Fiberglass and Composite Boat Building 1 06-16-2010 12:48 PM
Mold for sell, 36 feet sailing monohull, deck and hull set vaiobuilder Marketplace 0 06-30-2009 11:46 PM
Gen-set for a Pilot-boat. toveri Diesel Engines 4 05-21-2009 11:54 AM
Eliminating Running Backstays From A Design LFH Fan Boat Design 5 02-15-2008 06:37 PM
37' Racing Catamaran Hull/Deck Mold set Mason Clifford Boat Molds 4 10-27-2004 09:04 PM
