| Best Steel for Hulls and Structure I've not seen any discussion on the better steel choices that are available to a boat builder for the hull and structure. Are there any alloys with some small amounts of nickel or copper that are not cost prohibitive? I was reading here http://www.keytometals.com/Articles/Art60.htm and was intrigued that just 3.75% gave some very nice corrosion resistance. And it surprised me that 0.635% seemed like it just the right amount of copper because going higher didn't improve things and actually made it slightly worse for the "Continuously wet with seawater" category. Anyway, I was just curious what are the better properties and percentages to look for in steel. I was reading about A242, which seemed very interesting, but I don't know the cost of it and it it's any good for a ship hull. A440 and A441 also seemed interesting. A373 and A36 looked nice, but not as good as the others. I'm also interesting in knowing if you need any repairs, how readily you can find the steel in question--I don't want some exotic product, but I do want to learn if there is something offered that is readily available and is affordable and does offer some added protection against corrosion. Thanks for any posts, I think this would be interesting information to know. |
| Common is the Grade A shipbuilding steel, better a HT steel like GL A 36 (HT stands for high tensile). Corrosion resistance is not the important factor, but strength! every steel will corrode in seawater when not protected, even SS. For a boat of your size, common AH32 is sufficient, donīt worry. And it can be replaced in case of trouble in every port and every other anchorage around the world. If corrosion is bothering you, build in Monel, that will never corrode and you can skimp on antifouling. But beware! The hull and deck will cost you the same amount as a yard built, complete boat in aluminium. Regards Richard |
| A36 will be the most readily available steel in the states or you could get 44W from Canada with upgraded properties . |
Thanks for all the info, especially AH32 and GL-A 36. It looks like the AH32 has a Tensile Strength of 440-590 and AH36 is just a bit more at 490-620. |
| Back in the early 60's the Johnsons, contributors to Nat Geo. built their new boat it was constructed of COR10 steel (old spec A242 cortenA now A588 cortenB). It is a paintable steel that is meant to rust if exposed, the rust not flaking but forming a protective coating to the surface. Neat stuff. Cost obviously varies where you are on the world. It is not cheap. It is however a viable alternative. Regards, Jon |
| I have a 40ft yacht built from Cor10 steel launched in '78, not only is the steel extremely resistant to decaying rust but absolutely bullet proof (handy when striking coral knobs at 6 knots). If you can build your hull with Cor10 (commonly known as "Weathering Steel") then go for it. |
...have a replating of a 10 cmē in a underwater area........... Or, no, skimp on it, you have just 2000 miles to go to the place where they have it........... Docksitters donīt need any reliable material (Grp crap is ok, or better than that), passage makers need the very sophisticated stuff! Plain metal, bare wood, or the like. Corten sounds good, Monel is better, Titanium is perfect. choose...... |
| Steel Hulls | ScottK | Boat Design | 12 | 02-01-2010 12:38 PM |
| Steel hull with wooden structure | Barron | Boat Design | 3 | 09-20-2009 05:37 PM |
| Durable Steel Hulls | Wynand N | Metal Boat Building | 11 | 01-27-2009 06:19 PM |
| Plate deduction for Steel hulls | robmill54 | Metal Boat Building | 2 | 10-10-2008 02:48 PM |
| Through hulls in steel boats | tpierce | Metal Boat Building | 10 | 04-15-2006 04:40 PM |
