Old 04-22-2007, 12:34 PM
Outcast Outcast is offline
Bertram 20 remod question???
I am looking for some info from someone that has some qualified answers to my weight distribution questions for a redo on a 20 Bertram:
Here is what I have done
Removed V-8 and outdrive approx 840lbs
Adding bracket and 225 4 stroke approx 520lbs motor and 185lbs bracket (keep in mid that the bracket is a positive flotation bracket that allows 250 lbs flotation)
Moved batteries to front (100lbs)
enlarged fuel tank from 50 to 85 gal and moved 2 feet forward
added 12 gal fresh water tank forward of fuel tank
ANy ideas or thoughts will help
Kurt
Old 04-23-2007, 12:40 PM
jsh jsh is offline
Rep: 10 Posts: 25
Kurt:
The weight distribution is managed with the weight estimate, measured in ft-lbs,based on a common origin. When you know the position of the center of gravity for and aft (LCG) you can compare it to the center of buoyancy and get a feel for your static trim.
Determining the center of buoyancy requires the designers knowledge or you must measure the hull and do some calculations. There is a method described in Dave Gerrs Propeller Handbook.
Once displacement , center of buoyancy, and longitudinal center of gravity are known then you can quantify your changes.
I am working on an inboard conversion to a stretched version of the bertram 20.They were built on license here in the 70's someone splashed the original and stretched the 20 to 22 and the 25 to 28.
john
aftcabin bertram seadogs20 Boat Design 1 02-14-2007 01:21 AM
Bertram 20 DylanF Boat Design 1 11-03-2006 10:47 PM
Bertram 46.6 seadogs20 Fiberglass and Composite Boat Building 9 01-13-2006 09:19 PM
46.6 Bertram seadogs20 Marketplace 0 01-10-2006 10:17 PM
Bertram 390 gypster Powerboats 2 11-20-2004 10:28 PM
